Build Fly By Night
The output side of the LC steering column measures out close to an 11/16” x 36 spline. Does this sound correct?
I get 21 splines and about 3/4”, but maybe 11/16” is correct too.
I aint tellinn RUSH what to do, but yeah, I did a 60 box and everything went together all stock and trouble free like
A wise man around these parts once said that he wouldn’t step over an IH Scout II box for an FJ60 box, and fortunately for me, I have to agree, since my frame is already setup to run the Sag.
Four parts from Borgeson is more trouble-free than what most of this build has been 😂
hi RUSH ,
don't forget to torque down to fsm spec's , measure bearing pre-load with spring scale and STAKE BOTH DETENTS of the new flange hex nut ........
yellow paint dots work for initial pre-load phase well , sharpie day glow u shake the thing and the metal BALLS are inside , that type ..........
hi RUSH ,
Hey @ToyotaMatt , since you chimed in with this, here’s a question -
Do the detent plugs normally have a sealing washer between the hex head and case housing? This is a 38mm case converted to manual shift, so the front output manual engagement shaft and detent were sourced from another t-case. I don’t recall there being a washer and didn’t find any, for either the front output or the HIGH/LOW selector.
define and elaborate what a detent plug is or does , and the HEX HEAD housing please ?
thanks
" Do the detent plugs normally have a sealing washer between the hex head and case housing " 🤔
red digital ink is best to ID parts with mulit use or assigned terms if you follow me here some time ...
