Build Fly By Night
If not try not to use brass fittings or plugs to keep the galvanic corrosion to a minimum, no matter what you do that tank will out last the pig your bolting it to so most of this is more about preventing the funk that plugs filters
Aren't most AN fittings Aluminum now??? Anodized an fairly inexpensive????
Yes but as you know E10 is an ethanol-blended fuel. Phase separation is a real thing and you’ll end up with a layer of water sitting on the bottom of the tank, given enough time the aluminum will start getting the white corrosion and flake off into the fuel. I would be more concerned if the tank was built from steel.
This is a lot less of a concern for Rush with his 5xxx series aluminum that has excellent corrosion resistance but if he was going to try to hedge his bets now is the time.
So far with some net and YouTube searching, best results for the Bonderite type treatment involves a thorough surface cleaning with Alumi-Prep and a Scotch-Brite type pad. That is unless now there’s a hands free method for prepping that I haven’t found...
We used to just dip the parts in phosphoric acid based cleaner then rinse with water then straight into the Alodine.
Guessing if you dumped a gallon of Alumiprep 33 in your tank and sloshed it around for a few minuets it would be good to go.
Put the frame back onto to rotisserie in preparation for painting, hopefully, here within the next couple of weeks.
Won’t you be my neighbor? Well, how ‘boutcha neighbor?
Looks more like the Sanford & Son yard!
