Build FJ55V : This little piggy came home.
Member Build Threads
Howdy all.
Quick update. Have been in lockdown due a recent outbreak of Covid in Sydney NSW, big deal considering no recorded cases for almost 3 months. The 2H has been suffering from producing a large volume of White Smoke whilst running. We'll be replacing the glow plugs and checking for any injector issues, throw in a compression test and see how this motor is.
Aiming for 400psi.
See if I am up for a rebuild/New motor.
Things could get wild
Parts have arrived for the Transfer Case 2WD/4WD seal.
Thread I'll be using; '87 FJ60 - Transfer case leak - https://forum.ih8mud.com/threads/87-fj60-transfer-case-leak.874202/
Instructions in photos.
Should be able to do it without taking apart the Transfer.
Turns out I had ordered the wrong seal. Nothing a bit of RTV Sealant and a good clean will do.
Reinstalled with a new boot and works mickey mouse!
Got back into some welding and finished off the first round of the floor. Going to flap grind the high mount down and then weld back around all the holes I missed.
Here's also a photo of all 3 Sticks.
PTO > GEAR > HI/LOW
Here's also a video of me not using correct PPE to weld in the floor.
I'm quite sick and am low on beer. A bad combination
Hello friends.
I've been out of action the last few weeks with Work/Covid restrictions here in NSW.
Made some good progress with the intercooler. Pipework needs to arrive and I need to make a bracket today so we finish off.
Rust repairs start with the front end. Bonnet front section reskinned and pinch welded like factory.
Intercooler Heights worked out well for the scoop entry.
Had a few days off and jumped right back into it.
Intercooler mounted and paint trialing. Love the green.
We're into our next stage where you guys will enjoy
55's new home. We're finally starting on the roof rust. Needed to remove the 33's and slap on some Toyota Prius wheels. Bit of a difference!
Roof inner channel template mocked up and rolled. Will be making a few contours for future 55 rebuilders. Bobm hit me up.
