- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,507
Great details in those pictures @ToyotaMatt
Heck yeah, let's do it!would you like to participate in todays FJ55 T- series CODE CUT KEY , on my TOYOTA Computer SST Professional Sample Program ?
- ONLY , one willing TEST Piolet per day 1 time a week to be clear
have 1 of each, never noticed battery box location, going to check it out tomorrow, thanks for your eagle eye
I should have mentioned that the eagle eyes were two other pig owners @DEW1 and @theSherpa that came over to look them over. Also, the rear license plate light on all of them shone up, and they said in later years it was above the plate.
yes, and also has the old fuel pumps remote screw on filter, not the older element style can, and all the things a 1F had on a 40 series.Looks like both have the factory fuel filter bracket still that holds the glass bowl style.
Do you know where I can get one of those early air scoops?To add to this thread I’m comparing 1969 with 1971 piggies. The 69 did not have power brakes and the master brakes and clutch were shifted more to the center of the firewall because there is a air entry box on drivers side corner. The grill that’s mounted on the fender is actually operating- open to this passage. The first two pictures are the 69 the second two pictures are the 71. As you see the 71 does not have that air passage instead the charcoal canister tube goes through it.
Are you talking about the rear cargo glass or the rear door fixed glass. I believe they both are the same, but not positive about the rear door glass. I think the only difference between some years are the front doors, naturally.Will 1973 quarter glass fit a 1975?
I meant the rear cargo glass. Sorry about that.Are you talking about the rear cargo glass or the rear door fixed glass. I believe they both are the same, but not positive about the rear door glass. I think the only difference between some years are the front doors, naturally.
and there's is another variation of the seat hold downUnder the rear seat, the early ones did not have a latch, have it on the 71.
