- Thread starter
- #41
But being so old Gene you already knew that.![]()
Very cool. Wondered what ever happend to you and your wagon.. love the 40. Dash is awesome.
Do you have a build thread on 60?
Yeah I do, but I'm not sure how to paste it from my phone. It's in the 60 section under the title: My First Post in the "60" Section - '84 FJ60 Daily Driver
The LV wagon thread should be active again in about a month.
Curious about whats looks to be vents near your hood hold down latches?
Is that some sort of reinforcement under windshield hold brackets? Very neatly done.
I was going to mention the possible loss of side visibility/head clearance on entry/exit due to the lowered side door ways but if your good then go with it. It might create more flapping of the sides at higher road speeds (possible since you have a V8 in that truck). How is your visibility out of the rear view mirror with the lowered rear edge of the top? I have always wanted to lower the rear view mirror in my truck to see out past the lift hatch window in the back when the hard top is on it.After I was done I jumped in and took it on the street and the vision was good
View attachment 1491180Here is an idea you might consider for the door jambs on your top... I used two factory hardtop upper door jambs attached to the windshield frame and the home made b pillars. In the winter I can install hard doors and use a clear shower curtain attached to the B pillar to hold in the heat and keep out cold rain.
HTH,
Will
(sorry for the poor picture- the velcro holding the canvas to the jamb came loose)
Well the boys on here were right, I've been cutting the sides and back openings up 1" at a time and each time the improved visibility was worth losing a little shade. I'm up 3"-4" higher than yesterday's pics.
Mark, I thought that might be an issue so I talked with the guys at Galpin about sewing a 5/16" polymer rod under the canvas at the edge of the area over the doors. I'm not sure if it'll work but I'd really like to leave that stretch bowless.
