FJ40 flasher
pueblo west colorado
Good Monday cruzer land.
I have a quick question about a flasher. I need to replace my flasher and none of the part shops carry the one that looks like OEM. They are very light and small in comparison. At the same time they are only $5.00 as compared to $35.00 from Toyota.
1. Should I order one from Toyota?
2. Will the one from local store work even if they feel and look different?
Thanks for the help, any information will be appreciated.
Ted
:bounce:
Ted
:bounce:
OEM ones are prolly old school tech and have mechanical parts (as in relay, magnets and points) and new ones are solid state which will be lighter. Buy it, its only $5!
Flasher?
Do you mean like this?
a part like that I have no problem buying from a place like Pep Boys - and did when mine failed - rather than going for the pricy dealer model.
With electrical components, I sometimes like the convenience of plug and play. I spent the extra few bucks for a stock turn signal flasher from Toyota, plugged it into the harness, 1 bolt to hold it on and was done. Works great. I don't see why a standard NAPA type flasher wouldn't work for our trucks as basic as they are.
I also have a flasher question about the hazard circuit while we're on the subject. I am currently repairing my wiriing harness, and have noticed that my entire turn signal and hazard circuit is wired with just the stand alone turn signal flasher only. The '71 wiring diagram I pulled from the tech section shows a seperate hazard flasher, which I don't seem to have. Is this normal? The wiring at least in this circuit seems untampered. Truck is a 3/71 FJ40.
I also have a flasher question about the hazard circuit while we're on the subject. I am currently repairing my wiriing harness said:
My 2/71 is the same way and the wiring is all original. Not sure why they show two flashers but the schematic says the emergency flashers were an USA option.
If you have a hazard switch, you should have two flashers.
same way the OEM wiring was in my truck, one flasher for both hazard and turn signals. sorry IDave ;)
BTW, anyone is welcome to the used flasher relay from my truck for free (now have aftermarket wiring) - if you can get it out of that awkward spot under the driver side dash behind the dash reinforcement brackets :flipoff2: even my relatively smaller hands did not find a way into there :rolleyes:
Interesting. Well, so much for wiring diagrams, eh?
I managed to pull that flasher out of a 72, Claudia, to replace my aftermarket with OEM, using my 7 1/2 glove size hands. You just need stronger fingers. :D
my left fingers are actually quite strong (used to play viola) but I still couldn't manage to get it loose........ oh well...........I left it as a lucky charm ;p ;p ;p and it holds the new wiring harness in place :flipoff2:
Don't know how you'd get that thing out of there with your left hand. You'd have to crawl in there upside down and backwards....:D
not in my truck ;); it's more or less straight up from the driver side kick vent, but deep up there............
Yeah, that's why I had to get it with my right hand, sitting outside the truck. :confused:
;p
honestly, it never occurred to me to try it from outside :doh: :rolleyes: guess if I really cared now, it could be another project on a short AZ weekend ;p
