Figuring out proper Pinion angle.
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
I know Ill regret this post, Because some people cant help but comment even though they dont have an asnwer. But Im dying over here. I did front and rear bearings, ring and pinion and upgraded front pinion to 29spline. I had to do this because pinion bearings were smoked, and front ring and pinion were smoked too. While I was under the truck already I swapped in new radius arms(hyperflex arms) the hyperflex is simply adding one more superflex arm(which I already had) same dimensions same, same, same.. I didnt think it woud be an issue at all. But there now a vibration(nothing earth shattering) but a vibration nonetheless. So Ive read everything, watched every video on how to dial in the pinion angle, BUT I still cant quite "get" it. Can anyone lay out how to figure the angle? I have a dial gauge and an electronic gauge. Have at it. Im trying to drive to Virigina friday morning. And I dont like small vibrations as they usually turn into larger probs. Thanks In advance. Cause this sucks.
the way I do it is measure the operating angle at each joint and compare. I use a harbor freight angle finder that looks like a cube.
Rotate the shaft so the end cups of the u-joint on the companion flange at the diff is vertical.
Looking from the DS, place the left side of the cube against the companion flange and take a reading, then place the top of the cube under the drive shaft and against the tube and take a reading. The difference between the two readings is the operating angle of that u-joint.
If you are running a DC shaft that operating angle wants to be 0 +/- 1 degree.
If you are running a stock shaft take the same readings of the U-joint at the T-case and determine that u-joints operating angle and then compare the 2 u-joints operating angles which should be the same.
Here is the helpful @landtank thread I used. I picked up the same angle finder at HarborFreight.
Well the true way is measuring the flanges, and see what difference, they have or do not have measuring off the drive shaft cannot give you an accurate measurement ,due to several aspects of you placing it directly on centered on the shaft top or bottom , it will make a huge difference . I would also find the flattest surface to do this, and take 3 measurements and average them out if there are differences
I don’t see how measuring operating angles are effected by measuring on top or on the bottom of the tube. Only time that comes into play is when calculating the length of the driveshaft
I'm not sure how loose those arms are, but could it just be that you have it set correctly but having two superflex arms allows the axle to rotate during driving negating your set pinion anyway?
Thats what I have been wondering and I re installed old superflex arm(that is solid,no plates) to check and see if that was issue. Problem with that is. The new OEM bushings I had pressed in Colorado simply fell out. My biggest concern is drivng 1200miles roudtrip to expo. I never drive it with shakes, or even a slight vibrtation(which is what this is) but it is a land cruiser everything is tight, everything is new for the most part. I think Im going to go for it, PLUS I am installing a factory wiring harness in it down in Va at another mud members place.
and with front double cardon removed the vibration is gone.
I would just lock cdl and pull front driveshaft before the trip and reinstall there. With the amount of miles you drive I would part-time it.
I am doing just that, it just kills me to have a prob I cant figure out. With just rear DS in, theres a slight ciclycal grrr which Im blaming on a beat u joint. BEAR IN MIND front vibration and rear noise are almost unnoticable to a passenger, But i can feel them. Im meeting up with a yota tech in Virigina so Hopefully he can help out. Most guys on MUD are solid gold.
I have drawn the coclusion the truck rides poorly with hyperflex, and its no doubt the issue. So Im either going to replace damaged superflex or go with delta arms or something. but these hyperflex make it ride bad all around.
Well the drive tube has zero to do with measuring the angles, it the Uni's and flanges do, they tell you what the real angles are, but the tube is so out of shape and because if you do not have it directly centered, you will never get it right.
Not sure if this helps, but here is how I measured my operating angles for when I installed my DC shaft. This is for the rear, but same concept. As mentioned above, DC shafts are picky. PINION JOINT OPERATING ANGLE needs to be 0º +/- a degree or so. You can see how I calculate that here:
This article helped a ton. Take your time, read thoroughly and make sure you understand it all. Also, driveshaft slope absolutely DOES come into play when calculating pinion joint operating angles.
Sometimes "problems" are just the nature of the beast, street performance and offroad typically oppose each other.
Sucks to hear that man, what lift are you running again?
@RFB Are you not running a DC front driveline?
6 in dobnson springs,king shocks whiteline sways. same setup Ive run for 2 years.
