thanks Jose, I DMed u on IGThis article helped a ton. Take your time, read thoroughly and make sure you understand it all. Also, driveshaft slope absolutely DOES come into play when calculating pinion joint operating angles.
Driveshaft 401 & One-Ton High Angle CV Driveshaft...
Driveshaft 401 & One-Ton High Angle CV Driveshaft from High Angle Driveline By BillaVista Go to ---> Part 1 - Definitions and Operating Descriptions Part 2 - Driveshaft geometry / How to Choose a Driveshaft Part 3 - Driveshaft Maintenance Part 4 - U-joint tech...www.pirate4x4.com
So that I'm clear on this: the front still wraps down under throttle even with a high pinion?
Then you want the driveline and the pinion shaft to form a straight line one into the other. Zero flex/angle on the U-joint at the pinion.
Go part time and be rid of this headache forever no matter how much messing around you do with springs and radius arms.
Not sure if this helps, but here is how I measured my operating angles for when I installed my DC shaft. This is for the rear, but same concept. As mentioned above, DC shafts are picky. PINION JOINT OPERATING ANGLE needs to be 0º +/- a degree or so. You can see how I calculate that here:
Build - Evolution of a Land Cruiser: My 80's build thread
forum.ih8mud.com
With regards to a car, the slope or operating angle of the shaft is relevant because we know that the companion flanges are usually near 90 degrees to the shop floor (unless the pinion is angled upward like when we run a dc joint). Therefore, once the slope of operating angle of the shaft is more than 6 to 7 degrees, achieving a perfectly smooth running shaft under all conditions becomes more and more of a challenge with every degree or every inch more we lift a vehicle. Also worth mentioning is the fact that shaft rpm increases when we gear the differential down so it’s more than one factor that causes us driveline headaches.So we could go all day long, the whole point of the pinion angle but universal joint is to cancel out the pinion angles and the slope has absolutely nothing to do with it, and another thing a cardin is not a CV joint due to that it will bind at a certain point, and the articular in pirate off road is incorrect .
