I have fender flares on my 40. I want to take them off and get back to the stock look. I assume that the PO cut something out to install the flares. I thought I'd seen this somewhere but isn't there a cutout piece that someone sells that I can take to my body guy and have welded in and painted?
You can get news sides and the lip replaced... or... a good body shop will make their own (by pics you provide) or there is/was the rear PO flare delete plate (3/16” plate with factory cutout) by mud member @Fast Eddy
I have a pretty good body guy so I will likely take it to him. I imagine if needed he could weld something in and paint. I want it to look original. Hopefully it will be a matter of drilling rivets out, filling holes and painting. I've had the truck for about 30 years and have never liked the white flares. I guess you could say that I get something in my mind and don't let it go. I'm going to have them taken off this summer and that will have it back to square one.
Here is a side shot. The suspension is original. The tires are 33x9.5 BFG mud terrains. Wish they still made them.
"Always" garage kept. Just rolled over 100K miles. Only driven with the top off which in Oregon means not often. The "only" rust is shown where the top (which I have) attaches to the body. Surface rust. Might paint it someday but the might decrease the value....if I were to someday sell it?....which I probably won't.
I agree with you. You have a great looking rig and I think it would look much cleaner and original without the flares. If it were me I would drill out the rivets and see what it underneath. If you dont like what you see, rivet it back on. You should be able to feel if the fender has been cut. Take them off and have a reputable shop fill the holes and blend the paint. Get those things off!
Why not jack up one side of rear, remove wheel, lay under axle and eyeball the underside of the wheel opening, run your fingers along the bottom edge of the opening? You'll find out pretty quick if it's been cut up. Easier than drilling out rivets, just sayin'...
That’s been cut for sure. The opening is big. When installing those flares most usually trim about two inches out of the wells to fit the flares and bigger tires. If it isn’t cut you would see the body below the flare.
If there is a lip on the rear wheel openings then it's likely they are still uncut factory rear quarters. Sure looks like the front portion of your fender opening has a lip. Look or run your hand under there and feel.
I think I saw you comment in JohnL's build about rear quarters. The reason his openings don't have the lip is, his tub is an aftermarket aluminum Aqualu.
