Fed up with your crappy 80 series battery mount? LCP has a fix
Phil do the stock cables need to to modified to run a group 31 battery with this kit ?
If the battery post are on the correct side factory cables will work fine with all batteries including group 31.
If ? the posts seem to be in the middle on the group 31 battery's so I take that as a yes
Normally the only wiring that is stressed it the fusible links and our relocation included in the kit addresses that.
Ordered
So what do I do when my new bracket rips through my battery box?
Guess I'm on the lookout for a new box...
Is this still available? I haven’t found anything that will hold battery down haha. Thing is just floating around in there
When do you expect the dual battery kit to be in stock again?
From the manufacture ....they are on the way. As vendors currently we are at the mercy of the manufactures. We have a list of buyers we refunded as we wait if you are not on that list you can PM me your contact info and we will reach out once the brackets are in our hands.
I’ve got a half dozen dual battery sets from Phil at my shop. I can get you a set to sell you. I need to see your truck too!
What was Toyota thinking with the crappy FJ80 battery hold down. :doh: When the factory J hooks tear the box (and they will) the battery hold down bracket comes loose sparks will fly as the hold down bar shorts across the terminals. Worst case it starts a fire and your 80 series gone.:eek:
One of many actual picture below on failure that have occurred.
Also included in the kit is our fuseable link anti-stress set up. Fuseable links stress related damage is another problem that is address. By relocating the fuseable link connection to the back of the battery box you will no longer subject your fuseable connection to damage leaving you with a non running vehicle.
Battery Bracket Upgrade - Land Cruiser Products - LCP
Available for single or dual batteries
Template for new holes needed for L rod available on our web page in PDF
Whats included in a single battery kit below
Shown below our new clean battery hold down and secure battery fuseable link set up. (Works with all batteries up to group 31)
Some clarification on our anti-stress fusiable link connection/set up. By using the included 6 gauge 9" jumper you will be relocating the fusible link to the rear of the battery box. Once relocated they do not see the abuse being out of harm way given when guys upgrade their battery or take them in and out.
Note the red jumper installed to the back of the battery box
upload_2018-9-10_17-13-29-png.1786337
Take note of the correct assembly order of the hardware, jumper, and fusible link below. This connection should be very tight using 2 wrenches.
upload_2018-9-10_17-16-13-png.1786339
Rear view of the back of the battery box once complete. Notice the chafing from abuse of the pre-existing fusible link.
upload_2018-9-10_17-18-25-png.1786341
Like most of our product this is not something we dreamed up overnight and released. I have run the same set up with a group 31 for 5 years and 60K miles with a ton of the miles off road.
Hey Phil,
Any chance you offer just the washers, nut, and cap for the Fuse-able link? Bought the kit last year sometime and lost my in a recent move... :doh:
Thanks
Jonny
Hey Phil,
Thanks
Jonny
PM you shipping info and I will send it
Ordered!
Any solution to repair the tray if the L arm/ J hook tears through? It was solid for a year or two but it’s been torn for a while now and the bracket is barely holding the battery in place.
Fender washers ?...it sounds like your box may be old.
Same thing is happening on mine, but I'm pretty sure LCP is right in that my box is old and brittle
Use fiberglass to reinforce the hook slot in the battery box. I think I used JB Weld as the epoxy with the glass cloth.
