Fan going wrong way... haha help
Burlington NC
Fan going wrong way... now shes underwater haha i really am dumb
OK so i just got around toinstalling the fan clutch and blade, and i think they sold me the wrong fan clutch or something cause when i turn the car on, the fan is blowing onto the motor, not on the radiator..
if this helps the fan clutch is from advanced and says torqflo on it:doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh::doh:
That's what it's supposed to do.
The fan pulls air through the radiator..............:lol:
haha damn.. ok
Those damb metric fans!
Dynosoar:zilla:
justfor the record, my car has been underwater all night
ill hopefully post pics at some point
i cant get it out though, so this may not be good
lol
lol
how deep? is the water running or standing?
did you get stuck or did your motor die?
wheres the pics?
oh and good luck with the extraction
I have noticed that despite many attempts on the board here, 80 series do not float. It is clearly a design flaw in the muffler bearings and should be subject to a recall at any moment.
:whoops:
its pretty deep, i mean i had a big block chevy on 44's trying its damnedest, until his tranny got stuck in R
any suggestions?
its stading water, and i am straight stuck
the intake is underwater halfway too.. im f*cked?!
Got a buddy with a winch? how far from dry ground are you?
are you stuck on your diffs or frame or maybe just driving on grease?
I would not start that motor if the intake is half way underwater
the tuna can seals up but not that well
when you do get it out maybe pull the plugs and crank it a couple times to make sure that there is no water in there. once back you need to do lots of maintenance
diff fluid drive shafts motor oil etc... HTH
yeah,i just called a towing company, its gonna run me 100 buucks but at this point, its worth it
im gonna get it towed to my driveway, so i can let it sit till i can do EVERYTHING you guys suggest to do before puttin her back on the road...
its laying on the frame on the back and the front theres no tellin cause its so damn deep...
the rear end is sitting on dry land, granted i cant see any of the pass tire, the rear drivers side is i mid air
that pait a picture for you a little better?
thanks for all the help, what all should i do before drivin it again?
anyone in NC with a winch want 80 bucks to help me>?
haha i'd save 20 at least
