Fan going wrong way... haha help
If I was around Id help :flipoff2:
also with the truck sitting in water that long you might have water in your knuckles
that will lead to bad things
good luck
s***...
i have 110 bucks to my name right now and this is gonna cost 100...
im gonna head down there i guess... we'll see if the towing company can get me out.....
With deep water the last thing on your mind should be the mechanicals. Other than geting the motor/tranny/transfer drained and refilled; run to temp; drain and refill again.
The bigger issue and one that will plague you is the electronics. I know this from experience. I have no doubt that the big ticket mechanical items will be just fine in the long run, assuming you didn't suck water into the intake and shut the motor down quickly.
From your last post I take it to mean that the truck fell into a hole on the passenger side front?
Good luck with that.
yeah, the front passenger side is the deepest, but the whole damn truck is in water
its gonna be a chore gettin it out
You could use the other ten bucks to get some pictures of this stuck rig
best hope payday is soon as synthetic fluids are not cheep
if this is the way you wheel all the time a winch at both ends can help a lot worth the 2.5-3k for all that is needed (all new parts, 2 12k winches, front bumper custom fab rear mount)
and in the future let your friends with the big blocks and 44s got first and watch them get stuck in that :cheers:
Hmm, Sounds like you got one of those S. Hemisphere fans by mistake. You need to install a N. Hemisphere one, then it will turn the right way :rolleyes:
