Failed CA smog, need help please!!!!
So Cal
So I've failed my smog for this year on my rig four times already and can't seem to pass. Can anyone, especially smog pros, help me out or direct/advice me on what I can do to pass.
Look at my results...
8/12/16......UPDATE.....
Success!!!!! Finally passed my smog test on the 6th attempt. I want to say that the reman'd AFM along with the injector services had something to do with that. So thanks to all that helped along the way and guided me to the right solution.
A bit background info: it's a 94 FZJ80 with 349, XXX and runs great!! I did HG back on Aug 2014 and all went smooth except for an oil pressure issue that fixed itself out after a nice long drive. O2 sensors replaced twice; once in Nov 2013 and a second time in Aug 2 2014. First set were Bosch and second set were NTK/NGK, Bosch were still within parameters but replaced due to possible coolant contamination.
damn, sorry to read that man, and now I'm gonna have nightmares about it too....
I suppose in a sense the fact that it's so far out of whack may make it easier to figure out. I thought it was interesting that for a couple of them (could not figure out the date order, likely important) idle CO was pretty good but not the fast run, and that HC was good but not CO. That may tell an expert -not me, sorry- something.
Good luck.
Between first and second time, all I did was basic oil/oil filter and air filter change because oil was dirty and air filter was clogged. I really thought I would have no problem passing especially because I had just done the HG the previous year. So my second failure was horribly bad compared to my first failure. Between second and third, all I did was EGR components and throttle body stuff and did as bad as second. The fourth time was way better and almost passed. See results to see the numbers. Let me know what info you need.
Msapers- how can I tell if my cats are bad? I sort of checked temps pre- and post cats to see if there was a temp difference. I think there's supposed to be a difference and that will tell if they are good or bad.
e9999- sorry about the order of the results, they were in order when I uploaded but for some reason they got moved around. The dates are on the bottom left but the sequence goes 2,4,3,1. Thanks anyways, I appreciate your input.
Yes. About 100deg and should be hotter on the OUTLET of the cats.
If all else fails *cough* denatured alcohol *cough*
NLXTACY- I wanna say 100' difference is what I found reading around post-cat than pre-cat and i want to say that's what i measured. But on checking the temp, is the engine supposed to be reved or not?
Side note- this additive you speak of, what do I do, just pour rubbing alcohol to the gas tank? How much and when? Right before emission test? Sorry, not up to date with these additives you speak of.
watch out for water content in the different rubbing alcohol formulations - too much water will make for terrible sounds from your engine - BTDT
Try a different state.
All jokes aside, I think you need a new catalytic convertor. (I was going to say cat, but realized people will think it's just another joke).
My very rough impression of this is that the Cat does mostly HC, so may not be responsible for the big CO ?
I would clean MAF sensor and then change your O2 to denso sensors. What's your timing? Needs to be be at 3 degrees or your CO will be a bit high.
Also clean throttle body, change spark plugs and wires, dizzy cap and rotor, you know the standard tuneup stuff.
Where at in So CAL are you? I can suggest a good smog station in North Orange County that might be able to help...hint hint!
New cats is my guess. I was failing smog in the exact same category you are and also replaced a whole bunch of stuff only for it to be the cats at the end of the day.
