NLXTACY- I just checked O2 sensors resistance and per FSM, they should measure between 5 - 6.5 ohms across terminals +B & HT @ 68F and both measured well within the specs. And FWIW, the old ones I took off had NTK on them so thats exactly what I have on now.
Can I just say....thanks to all for all the input/advice given here. This forum is awesome especially when a lot of members chime in with their knowledge and personal experience. I have done my research and can not find anything that sounds like my issue. With that said, does anyone know if maybe the fuel relay may have something to do with this? Sorry if I'm asking for too much, it's just that I'm really wanting to get my truck back on the road, it's missed way too many road trips to a jeep grand cherokee .
Interesting. My FSM says resistance between +B and HT should be 11-16 ohms at 68F. But regardless, these terminals are just for the heating element inside the sensor, _not_ for the sensor output which is what the ECU cares about for engine control. The sensor output terminals are E1 and OX and that signal is supposed to be a "sawtooth" waveform that is best measured with an analog meter or an oscilloscope that can "memorize" and display slowly changing waveforms. If IRCC, the meter needle should fluctuate 8 times or more every 10 seconds both at normal idle and fast idle, although I'm not finding that spec in my FSM just now so it may be in another Toyota document.
But all this is just an aside. I'm with Pin Head on this one, you need to pull your injectors and have them serviced since I'm betting at least one is leaking fuel. How many miles on your 80 anyway? Sounds like you've never had the top end apart and if a high mileage vehicle then the injectors could certainly be in need of servicing. I've used WitchHunter with good results in the past, although you may have some place in SoCal that has an equally good reputation.
The only way I know how to test an o2 sensor is to pull it out, stick it in a vice attach a multi-meter to it and blast the hot end with flame. Its a piezoelectric device so it should produce 1 volt (some produce 1.5, 2 or even 5 volts not sure what the spec is on the land cruiser). If it doesn't produce the correct voltage its usually bad.
I haven't read Toyota's test method but from what I've read here it wouldn't actually tell you if the piezoelectric portion of the o2 sensor has failed. That can only be known at temperature at-least by my very limited and usually flawed knowledge.
Now if that's the test method for testing the heating element it makes more sense.
Knock sensors are piezoelectric, not O2 sensors. O2 sensor are chemioelectric devices and need both a reference O2 concentration (outside air) and a sample (exhaust gas) in order to produce a voltage proportional to the different concentrations.
I'd be very careful if you try testing a sensor with a propane torch. Typical EGT's for gas engines are maybe 1400-1600F max, while the tip of a propane flame is 3600F.
Etarasoff- I do happen to drive a VW as my DD, but is swapping possible??
Qball- yeah wish mine was a diesel as well but that only happens to the rich and famous!!
NLXTACY / TrickyT - I'm surely not doubting you guys one bit but I must have a weird FSM cause mine tells me to test the heating component and that it should be between 5-6.5 ohms. Regardless, my copy is probably not accurate. I'm just totally lost.
SmokingRocks- yeah I did test the O2 sensors with a torch prior to installing trying to compare with the one that came out. They were both good but still installed new cause I had them. And I only used flame for a short bit due to higher temp.
TrickyT - just to answer your prior question, I did HG Aug 2014 and unfortunately, the only service I did to injectors was give them a good clean and made sure the resistance was WINL. So I may have to do that just to rule out a leaky injector(s).
94's are notoriously hard on O2 sensors. Ask me how I know! I was throwing codes years ago and I ran every test the '94 FSM said to do in proper order. O2's passed all of the tests. Replaced with OEM anyway and codes went away. Outside of when these suckers were acting up, I've passed every smog about as clean as you can get. Not much real help for you but sounds like more than O2 sensors.
Brentbba- yeah I've heard about the 94 and it's little appetite for O2 sensors. But at least for me, no codes at all...only ABS but thats a separate issue. And I do hope it's not the O2's.
e9999- I'm all for that idea and might as well have a few spare rig loaners for issues like these. That way, any member from the community can use them when they really really need them. I will volunteer my rig, someone take it and fix it while you have it.
On a side note, I took my rig to some shop to just get this "monkey off my back" but the guy wanted $1100!! I reiterated that all I wanted was to just pass and then he said $600 ( a little too rich for me). Sooooo, I'm screwed unil further notice. I will heed the advice and am biting the bullet and removing fuel injectors and sending them in for service as soon as I can. Thanks once again for everyone's help/advice/knowledge given, much obliged. In the meantime, I will .
