Failed CA smog, need help please!!!!
Sounds like your truck accidentally doesn't have a cummins in it.
All joking aside I'll absolutely do the cummins swap prior to moving back to SoCal. Those emissions standards are insane - but I guess they do create jobs.
Hope you get it sorted. That sucks!
Yup they are strict here BUT they don't impose more restrictive standards to older cars, they just need to pass the smog standards when they were new. Pretty sure it's just some tuneup issues and possibly cat.
Thanks to strict emission standards we can actually breath here. I don't think people who complain about our emission standard understand the amount of cars here and how bad the air was 15 years ago.
Here is why we need strict emission standards(that's Monday morning 7:41 am, sunny! map shows freeways in 4 counties!):
Stay home!
:lol:
Pin_head- I did see that list or something similar to the one you mention about likelihood of issue and I did run tests per FSM and it appears they were within specs. Except for a possible leaky injector, I can't verify or dispute that they are leaky but they measure within spec and using a listening scope doesn't reveal anything weird as they all sound about the same on idle/rev.
I don't know of any way to check the leakiness of the injector without removing them. On all tests, you are way over on CO, so I doubt that new cats are going to cure this. They would be a band aid anyway, since the CO% should never be that high to begin with if your air/fuel ratio was stoichiometric. It is either leaky injectors, bad MAF, or something else that is obstructing air, like a bad air filter. The fact that it is over at idle too makes it less likely to be an air flow problem because air flow is minimum at idle.
Sorry trying to catch up on the replies....
Dragos80- ha ha, I wish I could move out of state but we all love Cali!!
Landseer- I did try injector/fuel system cleaner already. I do that every so often just to make sure carbon is reduced.
Qball- I'm actually afraid to mess with MAF cause I busted one yrs ago, very costly experience. But it does measure w/in specs. My timing is 3' and hasn't changed. Also tune up was done about two months ago, included oil/oil filter, air filter, spark plugs, wires are still good.
82much- I'm in N orange county, La Habra specifically. You know of a place wink wink? Hook me up man, I'm dying w/out my rig!!
NLXTACY- I wanna say 100' difference is what I found reading around post-cat than pre-cat and i want to say that's what i measured. But on checking the temp, is the engine supposed to be reved or not?
Side note- this additive you speak of, what do I do, just pour rubbing alcohol to the gas tank? How much and when? Right before emission test? Sorry, not up to date with these additives you speak of.
You want the cats as hot as possible. They work better when hot. Quick and spirited driving will get them where they need to be.
Your issue is high CO2 which my method won't really help you with. Don't use rubbing alcohol. Use denatured alcohol. Get it at Home Depot. 25:1 gas to alcohol. It's not an additive. It's a "get this monkey off my back so I can buy time to fix the real problem". Here is my before and after in my 60.
There is the exemption in the law where if you spend more than $600 (or whatever) on fixing it you get to drive it another 2 years.
My son in law was paying about $800 to get his 60 "fixed" by a well known shop and then 2 years later he had to pay the same amount to get it "fixed" again. After moving to SoCal, I checked it out and found that rats had eaten the wiring to one of the VSVs, one VSV was plugged into a light connector and the vacuum hoses were misrouted. After fixing all this minor stuff it actually passed just fine. The point is they took his money and didn't even try to fix it.
Check timing, try 3 or even 2 degrees, still a bandaid but it does lower CO a bit.
As far as MAF goes just use MAF cleaner and spray liberally into the sensor.
I would also try denso O2 sensors if you can borrow them. dr.gil just changed out his so he has his old ones as spare.
Oxygen sensors are dead simple to check. When cold, unplug and measure ohms. Should be 11-16ohms.
NLXTACY- thanks for the pix of the denatured alcohol, I will try to get some from home depot.
Pin_head- yeah I hear you, I actually thought it was one of the VSVs but when I took off the plenum, I rechecked them all and they all checked out. I had even bought the VSV for fuel pressure regulator but it was OK so I returned the part. But wouldn't I have a MIL show up? This is where I'm confused like ish!!! Absolutely no check engine at all.
If it was me, I would bite the bullet and have the injectors checked and rebuilt. A leaky injector is not likely to set a MIL until it is so bad it causes a misfire, which might be never. The fact that the CO is mostly worse at idle is consistent with a leaky injector because it has more time to leak at lower RPM.
Pin_head- sorry it may not be easy to see it but on my last attempt, which is the first pix I attached, I failed on high CO on 2500 rpm while my idle was about 0.16ppm, so idle passed.
NLXTACY- I want to say that I tested my O2 sensors and they were within those figures you gave but I will double check when I get home layer today and post results of those.
Yes, but that was only 1 out of 4. It only indicates that the problem is intermittent. You have to do something if you want to fix it. There is too much fuel on not enough air. Catalysts are a band aid for the problem because CO should never be this high in the first place.
If you buy a new cat or have decent cats not solving emissions issues are a sure fire way to kill them and cost you more money.
I, uh, had a friend who would remove/bypass/otherwise protect all emissions components after smog check so as to keep it all in working order. Then reinstall just before the next one. Not suggesting anyone do this (for the sake of the planet and all that), but it did seem to keep his/her components in working order and no trouble passing smog.
NLXTACY- I just checked O2 sensors resistance and per FSM, they should measure between 5 - 6.5 ohms across terminals +B & HT @ 68F and both measured well within the specs. And FWIW, the old ones I took off had NTK on them so thats exactly what I have on now.
