F to 2F questions
If it is off your old engine, what belt driven accessories did you have?
Probably an alternator and an air pump, eh?
One of those must have been out front with the skinny pulley.
My $ is on the air pump getting the skinny belt. Those are much more prone to seizing than the alternator.
It only had one belt when I bought and and no other stuff bolted on. Essentially trying to figure out if I need to buy a new pulley for $300 or not. Since I'm planning to get AC, I need one that'll handle that belt. Curious if anyone else with this pully has done that. Such a bummer the pulley I have is no good. The two front pulleys are good but the thrid large one is the one off kilter.
Well, you don't NEED a double wide groove pulley to run the power steering...it's just better. That's why I have a wide/skinny getting rusty in the basement and a double-wide in my rig. I did run the rusty pulley for many years with the saginaw P/S though...it will work.
Found this...
Pretty sure I got the oil pan sealed. Realized the side cover is leaking a little and running down. Retorqued those bolts. I'm sure I can get that tightened up with some attention. Didn't get to the crank pulley yet. Might have some time to drain and pull the radiator today though. Was reading that there's really no other option to install the new pulley other than to beat it on there, since it's a nut and no threaded hole in the shaft for an install tool to go onto. Any advice there? I'm guessing I can beat get it on until I can get the nut on the threads and finish it off.
I would polish the shaft with some crocus or emory cloth, debur the inside of the pulley and keyway. Wonder if heating the pulley in an oven would help it slide on easier...
Done and done! Pulley swapped. Not too bad really. Little leak running down from the valve cover still but I think we are there. Runs nice! Still hesitates a tad on initial acceleration but it's better. Tried the carb spray around the carb and intake etc and no change so I don't think it's a vac leak. Carb was rebuilt not very long ago so doubting it's that, but I'm no expert. It did not do this before the F blew and I didn't do anything other than take it off and let it sit for a few months. Haven't pulled the timing gun out...all by ear this far. Probably should do that. All in all, I'm ready to bolt the grill and number back on and call it done!
THANKS EVERYONE ON THIS AND MY OTHER THREAD. NEVER COULD HAVE DONE THIS WITHOUT YOU!
Congrats!!! I believe you’ve learned a lot in this process. Great to see the engine work come to a happy conclusion. Looking forward to meeting you and your nice pig in July in northern NM! Can’t wait to be back in the Land of Enchantment!
hah! Well I think I jinxed myself...:grumpy:
What I thought was a leak from the valve cover, behind the coil, looks like a much bigger problem. I think the oil is coming out of the head itself, above the 5th spark plug...just cleaned it all up, started it and watched till I could spot the leak...I'm terrified I have a crack in head. I assume this would be a really serious problem?????
I'm about to drive over the engine shop (5 min away) and just see what they have to say. I would think they would have gone over this thing before the rebuild...
this? think mine is a different spot on the head...
Ok, this IS my problem...
It is already threaded and the plug was loose! This better be it!!!!!!!!!
That was one of the first things I learned about after buying the pig. That's my handy work by the way. I can't remember if there's just one or two allen bolts in there. I read somewhere that it was better to run two in there, in case the first one tries to back itself out. Glad that was the source of your oil leak. Easy fix!
A week or so on and I'm still fighting this little hesitation issue right when I first hit the pedal. It only happens if I hit it full. If I ease into it, it's fine. It idles perfectly, and once it gets over the initial low rpm hard acceleration stumble, it's perfect.
Read a ton on vacuum leaks and carbs but every thread I've seen has a little different set of symptoms and nothing exactly like this.
I bought a vac gauge and it's sitting steady at about 16, which is a little low (read 18 when warm would be good). It's is very steady at 16. I've sprayed carb cleaner on every inch of the intake and it does nothing. Sprayed it everywhere there's a connection and potential leak and no change ever. Tried propane too. Nothing. Checked the hoses to booster, dizzy, pcv..all good.
Had Mark rebuild this carb a year ago. It was an 1983 aisin replacement carb for an F and per him was in fantastic shape. It ran perfectly on the old motor.
If I pull the choke about a third out, the hesitation thing goes away but overall it doesn't run quite as strong. I've been pulling the choke 1/3 when I get to stop on a hill and need a solid rev into the clutch so I don't roll back, then I push it back in. All other times I can feather into my acceleration and it's fine.
I also timed and and adjusted the mix screw multiple times per videos and threads I've found. The mix screw is probably about 2 turns at this point but has been in more and out more at various times.
Even replaced the intake/exhaust gasket (2nd one since new motor went in). I was worried about the header and intake not being perfectly flat. The one shop in town who could flatten them is out of business thanks to COVID. I have a jt header and used the thicker gasket...can't recall the name right now.
What about valve adjustment...can't imagine a freshly built motor from an experienced 2F shop would need this right?
Any direction is helpful. Spent the better part of a week trying everything I can and I'm not making any change. It's totally drivable but obviously after all of this it would be nice to get it 💯 right!
To me, sounds like a carb issue. The fact that enriching the mixture by pulling the choke part way out helps, indicates the carb to me. Maybe jetting? ABQ is about a mile above sea level. Was the carb jetted for that? I’d pull the carb and send it in again or, better, go fuel injection. It’s expensive I know. I’m putting an Affordable FI kit on my pig in a month or so, so I can report the supposed improvement. My pig had the same hesitation issue. I decided spending a lot of money and putting a lift kit, disc brakes and new tranny/tcase should fix it though 🤪🤪🤪🤪🤪🤪🤪
Thanks for the quick reply. I was starting to think more carb, but I just don't know enough. I've been contemplating the Sniper for a while. Heard lots of good stuff about it. Loud and clear on the disc brakes, lift, new trans, AC... ect...all of those are on my list too!
