Experience with Chromoly life
Recently upgraded my front axel with high strength chromoly axles. I’ve got. 5.3 LS swap and 44” tires, so figured I should go with the stronger axles & birfs.
I’m aware of the common trade off, now the truck should only be used off-road, as these axles will wear faster.
I’m wondering what life are people getting before these axles need to be replaced ? Most local trails are 1-2 hours north of town. Am I looking at trailering even for the closest trails ? What street use do folks actually drive?
What life-time are people getting from the high-strength, but wear faster chromoly axles/birf’s ?
I’m probably stepping into a can of worms, but how does the OG Longfield compared to the nitro chromoly ?
As far as I know the Nitro axles have a good reputation along with RCV axles, who made the Longfields for Bobby back when he was still alive if you didn't know.
Between those two I don't think you can really go wrong. But then again, you have a V8 and 44s so I imagine you'd have to be pretty damn easy on it to make them last.
Pics needed
If you are monster trucking around on 44's with a 5.3 who cares about axle life? Photos requested.
Pic ! Pics ! This thread is a serious request for info. ......But for those just looking for Toyota porn
Video on 6” springs, pics after lowered to 4” springs
Walk Around: Arctic Truck Vortec Swap
Seriously, looking for info on life expectansy of chromoly axles
RCV is 100% USA made and come with a life time warranty. The warranty may have a tire size limit attached. Wait a minute or two and they will be able to sell you a set 300M’s for the rear.
I think you would be safe around 60k miles. That was the original number Bobby told me and they have since been made a little harder for longer wear. I don't know about the Nitro kit, but I would assume it would be the same.
RCV has the best warranty. I had a damaged cage inside the birf and they sent a replacement no questions overnight!
I can't recommend them enough! Great people
So WHY are we Gun drilling a bird if we want the ultimate strength and lifespan? It probably would not make a huge difference, but I think it would make SOME difference? Ya gotta pull the square plug outa the top of the knuckle to check the grease level anyway!!
Even gun drilled, I am sure the Birf will let go before the outer shaft does. With heat treatment and the small distance of shaft to birf, it should never be a problem.
One would think so, but: years ago I was running 1st gen Longs, inners and ouster’s on my FJ 55. I had a bad day on the trail, yea, backing up hill while turning, and it went BANG!! The inner snapped at the snap ring groove. But before that popped, the outer splines inside the Asco hub twisted by more than one spline, without breaking?! Never seen that before. Bobby made good on them. He replaced them for free with the newer 2nd gens. I also bought a new set of 2nds for the other side. Oh, and the bell, ball, and cage were just fine on the side that blew up!
