Enough heat?
Do you guys have enough heat from your front unit? I don't seem to have enough volume of heat to get the job done. Maybe just the nature of the beast as this is my first 40. Just not sure how much to expect.
More than enough.
I didnt even bother putting a rear heater in mine.
Or clean off the heater core...they catch alot of crap over the years
Too much, most of the time, but we don't have much of a winter here in north Texas. The only time I ever wanted more, was driving back from southern Utah in April or May with some glass in the hard top broken out due to trail damage.
Evict the rodent nest in your heater box.
Yep, they sure do....:hillbilly:
img_0971-jpg.998747
You didn't provide your location or ambient temperatures. FJ40 heaters have trouble at -10F, in my experience, due to the lack of insulation in the truck. The only flushing that would likely help would be to remove the core and fill it with Muriatic acid (very carefully) and dissolve out all the calcium buildup from the past many years. A 'cooling system flush' is unlikely to make any difference.
Does your truck run a full operating temperature? (the head should read 190 or so with an IR thermometer).
SOR but then again the shipping.......
Bought a heater from Vintage Air and will install it later this month. Looks to be better with inside controls, a bigger core and a better defroster control.
I drive in flip flops even in winter. Solves some of 5he issue
Im gonna take it out and clean it good. As big of a pain in the ass as it is to get the top back on Im not sure if I ever will. When the top comes off this spring I may not put it back on anyway. Im thinking I may need a 60 for the winter.
