- Joined
- Feb 3, 2013
- Threads
- 55
- Messages
- 225
Hello everyone.
Ive reached a dilemma regarding my engine swap, I know part of it might be in my head but, i need to get my thoughts out and hopefully Hear your opinions if I am making a big deal out of nothing. and since i am coming to a point that i need to commit to a solution i thought i would ask advice from all of you.
When I purchased my 75 piggy it came with a 1f that one of the POs had put in as a swap for the 2f that the factory had installed, I have no idea why. it was always my intention to swap out this tired leaky motor for a 350 that I would build myself.
So with reliability and performance in mind I spent the better part of the last year (as well as the better part of 3 grand) planning and then building this sbc. The end result is a fantastic motor which I am confident will serve the exact purpose it was intended (run strong and reliable).
My plan was to do the engine swap myself using Marks Kit from AA.
http://www.advanceadapters.com/prod...ser-stock-4--5-sp-to-chevy-v8-conversion-kit/
when I pull the old tired F motor, I’ll Pull the transmission and transfer case and have them rebuilt they both leak oil but perform great this just makes sense to me to do this now.
Herein lies my dilemma, Ive done SBC swaps in several Corvettes(my late uncle used to restore and sell them), Ive done a complete engine/drive swap in my boat ( I even got to help swap a pantera motor ) but I’m starting to get cold feet about the swap I’m not sure why maybe because my piggy is my pride and joy and the fear of f**king it up is getting to me. My biggest concern is the actual fitment of the motor to the frame. Getting the engine mounts right and making sure they are in the right place. Not to mention all the little questions that come up along the way.
I am at a point where I am considering building a 2F motor and just putting it in an calling it a day but I know I will regret that. since its always been my vision to have a V8 in my piggy. But since I moved up to rural central California I have lost all of my resources / friends that could come over and give me a hand or be second set of eyes / advice .
I thought about having this portion of the swap done I called cool cruisers in Gilroy wanted 6k to do the swap. This just seems like a lot to me to do something I should be able to do myself so when I heard that it made me think that there might be something im not considering.
Here are my concerns maybe your advice can help put my mind at ease
1. I’m sure many of you have done this swap what problems did you run across?
2. I have never worked with a hydraulic clutch does this create any problems with the swap.
3. is the marks adapter the way to go?
4. will i have issues with the firewall?
5. AA also sells a cross member mount that they say is necessary for wagons http://www.advanceadapters.com/prod...nd-cruiser-crossmember-mount-for-fj55-wagons/ however the swaps I’ve seen don’t have this.
6. How do make sure you have the motor mounts in the right spot on the frame.
7. Do I need to remove my old motor mounts from the frame?
8. I’m going to either have the radiator rebuilt to be high efficiency or get a new one (aluminum) altogether any thoughts?
While I do quite a bit of welding I was planning on hiring a mobile welder to come out and weld the motor mounts in place. I follow the mantra “if I need something welded, I weld it myself, if I need something welded NICELY I hire a welder “.
Thank you to all that read this your comments / advice are welcome.
Rons da man
