Of course the 2F is worth keeping!
Don't underestimate the costs of a V8 conversion...
PabloCruise said:Of course the 2F is worth keeping!
e-man said:I set the timing with my ears and a close guess because the needle that is supposed to be in the middle of the timing window is either broken off or I just don't know what I am looking at. The timinng seems to be close enough as it starts and runs ok.
The Engine leaks from EVERYWHERE! Internally too. If it sits for a bit after running I think Oil is leaking past the valves and into the cylinders because it burns off a lot of oil when it first starts up.
I don't deny that I probably need a valve job and that the carb is way out of wack. I want a perfect running motor and thus I will get it rebuilt IF the 2f is worth keeping. Otherwise I am just going to drop a V8 in.
e-man said:This Thread is really gonna go astray now, but... Why the late F head on a 2F motor? I would assume that Toyota had figured out turbulence, VE, and other such important things better on the later head?
e-man said:The F head is designed for a smaller displacement engine though it would seem to me that it would be counterproductive. Would it not be best to have the 2f head milled a bit?
You are semi-correct sir.I get it that the F head has smaller combustion chambers than the 2f, but I would assume it also has smaller intake and exhaust valves. Seems to me Compression is Compression and if I can get to 9:1 or 10:1 with a 2F head I would be better off than the same compression in an F head.
e-man said:Basically I want the engine as big and powerful as it can get. That means boring it out, thus a rebuild. .
Pin_Head said:The max you can bore it out is .060 over and this gives you about a 3% increase in displacement. This is a spit in the bucket as far as performance goes.
If you are convinced that you have to have a lot more performance, go turbo or V8; everything else is just fiddling around with an engine that does not have a good volumetric efficiency to begin with because it is a 60 year old design.
FJ40Jim said:Pinhead: do you have a source for 1.5mm O/S pistons anymore? All of my sources have dried up. Biggest I can get lately is 1mm![]()
