Engine hand crank tool question
N. California
Did Toyota ever make a engine hand crank tool out of 1/2" solid rod or were they all made from 3/4" solid rod? Also were they all the same basic shape or did it change at all through the years?( meaning that from a change in shape, it was made smaller. So the new size hand crank tool wouldn't fit into the brackets that its suppose to fit on in a Land Cruiser)
I know early engine hand crank tools were short in over all length, and later ones were longer but want to double check on the rod size and shape.
I have attached photos of a OEM hand crank tool compared to one that i bought on Ebay which i believe is not a OEM tool.
I helped a friend rescue a 72 FJ55 and it had a hand crank under the back seat. We used it to turn the motor before we brought her back to life. It was an F155 so I'm not sure if these went away with the introduction of the 2F
I can't remember the size though.
Parts list shows 2, they differ by length, the early 850mm and the 1005mm used in FJ55s. Given the dimensions of the eBay crank, it would not fit the FJ40 wheel well brackets either.
Pickups and troopies both had the longer crank once the tire carrier style was changed to a hoist. Have one from a 84 troopies that is the same as the one I bought for a late model FJ55 back in the mid nineties. Never checked to see if the long ones to to long to fit in the FJ25. The early pickups had plently of room in the clips behind the seat.
the shorter rod in your first pic looks a lot like the Mazda p/u rod I have ... one of the telltale signs for me is the handle part of the Mazda rod is shorter than the Toyota rod and of course the diameter of the Mazda rod is smaller ...
ive had those cranks from 64 up to later models and other than length they were all the same still hanging on the walls around the garage .older power wagons had one similar
Great discussion, thanks all!
Anyone know where I might purchase a hand crank for my '75 FJ40
Thanks
Shawn
I have a prototype and templates made from a correct stock starting handle - had planned on producing a few runs and offering them up for sale . The main impasse right now is the storage clips - just can't get the right alloy bent without cracking the smaller bottom radius bends . If I can get past those parts I'd offer it up as a kit , probably re-visit the project this month again since I have more shop time . Need to test the handle I made as well to insure it won't pretzel with a good compression cold engine . I've already cranked out a bunch of the bumper-mounted guides for the starting handle , need to get the rest of the project finished soon...just finding time is tough .
Sarge
And just because...
hand crank?
I watched this after I recently hand cranked the 55 for the first time.
Now I know not to wrap my thumbs around the bar. Luckily it didn't backfire.
