EMSpowered exhaust
and both O2 sensors point straight to the ground. Dumb dumb dumb if you ever plan to wheel.
I am really really really peeved about the O2 sensors! The front one not so much although the location is a bit retarded, the rear one - completely idiotic. That, and the positioning of them has my OEM wire harness strung taut and not using any of the OEM retaining clips for the harness.
That does't sound right. You sure you didn't mount something wrong?
Mine point at a downward angle(ish), but they're not straight down. And there's plenty of clearance, long before the O2's would get hit all sorts of other important bits would get taken out (such as the T-case).
Also, while both my harnesses are tighter than OEM, they're not taut. IIRC the front sensor doesn't use the very last harness mounting point, and the rear uses all the OEM mounting points.
Now granted mine is the prototype, so it may have changed slightly but as far as I know it has not changed significantly.
The whistling is at the junction of the cat to the frame crossover pipe, not in the engine bay. Hopefully this can be solved easily.
How did you determine this?
I've always thought and experienced that with something as "custom" as an exhaust that one should have it done locally, in situ; I would have bought some of the EMS bits and had a good local exhaust guy route everything, weld everything and make sure everything was kosher.
Off the shelf for stuff like this is not my cup o tea, unless you were going to go OEM all the way--exhaust manifolds back.
I really don't understand why companies have so much trouble with this sort of thing. I bought a Borla system and it fit like crap, had it replaced and that fit like crap and now all this.
Help me out here, I pull my stock system out of the 97, use it as a template to build jigs and then replicate.
Sure I might have a few revisions while I work out the best muffler but what am I missing?
The larger size of the exhaust makes for tighter tolerances than OEM. Plus there are design differences, while it's loosely based off the OEM exhaust it's not exactly the same. The routing is slightly different, and the purposes are different.
OEM is designed to route well clear of any possible obstructions/interference, and be nice and quiet. The EMS exhaust is designed to be as tucked up as possible and provide the highest flowing exhaust as possible.
OEM is most definitely not designed to be tucked up, nor is it designed to be open and free flowing like the EMS exhaust is.
I think a big part of the problem here is that people don't quite understand what they are getting. They are expecting an OEM replacement exhaust, with similar characteristics. The EMS exhaust, while based off the OEM exhaust, is not a simple OEM replacement system. It won't sound the same or be as quiet as the OEM exhaust, but the OEM exhaust won't provide the same performance benefits or stay out of the way and not get hung up on everything.
For those who really hate the whistle, pony up $50 (or so) and get a resonator installed. It would not be difficult to have one added in if you desire.
I think you're right about expectations. I originally thought it was a direct fit with the exception of going over the frame rail behind the cats.
Personally, if I was to get into making exhausts for the 80s it would be a direct fit for no other reason than being 100% compatible with existing aftermarket accessories. It might not have the performance this one does but there would be a hell of a lot more happy customers.
I hate the price of the OEM stuff and the Borla and local shop really didn't satisfy me. There is obviously a need here and I hope EMS works thing out.
Positive, b/c of clearances there is no room for misaligning.
The forward O2 doesn't point exactly straight down. The aft one does. It is like a rock feeler.
Mine is taut, no two ways about it.
Looking at the photos of yours, yours is clearly different - at the cat and at the muffler.
O and I was totally wrong - the whistling is at the exhaust manifold.
Hopefully Baktash will check in shortly and have something to say about this and offer up some solutions. In some regards my expectations were exceeded - the sound is great, not obnoxious; routing is great (except O2's); clearance is great (except those dang O2's again). However, having to lose a heat shield, the t-case rubber isolator, and having the section of pipe over the axle touching the upper control arm mount are big downers.
Fortunately this can all be fixed. The question to me is, will Baktash fix it or are we on our own?
Well,.. I was posting in the vendor section and it's interesting to see these other complaints here.
here are my issues:
1. Cannot install mine. The pipe that goes over the frame does not in any way fit without me either removing the heat-shields or somehow bending it so it rests on the frame (which it partially does anyhow). Both are unacceptable.
2. Both my o2 sensors are now exposed to damage. The rear one is the lowest point on my truck. This is ridiculous. Tuck up part of the exhaust so that it doesn't get hit on the rocks but insure that my $100 each O2 sensors do. Great. Unacceptable.
3. I had to remove my Slee transfer case skidplate to get mine to even go up there and even if I got the exhaust to fit, I couldn't replace it because the exhaust would be in the way. Unacceptable.
The exhaust is billed as a direct bolt in. This is on their site. I also did not receive gaskets and mounting hardware and have spent even more money on this direct Bolt In exhaust, that should have gone in with no problem. I state in emails a number of times that I need my truck on the road, get no responses for weeks and it took me 3 Months to get to this joyous point.
Did I mention that I cut off my exhaust since it was so rusted together?.. worked fine, I was just looking to upgrade I guess but, now I have to buy the resonator section again just to get my truck back on the road after I rip this thing off my truck. I for one am not modifying my truck to make this thing fit... rubber isolator?...Heat shield? Transfer case skid-plate? BS.
I do not plan on paying for shipping costs and do not expect to have to lose the shipping to me on this deal as the exhaust was mis-represented both here and on their website.
"Bolt-on: mechanically bolt on without having to modify or custom build"
I will be seeing what, if anything is offered to all the people that are having issues before I make my decisions this week. I was not upset until I saw that they are not even answering to anything here. Hope that they are having a great weekend with our money. I for one had to cancel a camping trip with my kids because of this BS.
Bill
TLCA#7390
Abso-freak'n-lootly!!! Last custom exhaust I did I bought all the neccessary mandrel bent pieces for the routing I designed myself and had it cut and welded at a local shop for a perfect fit. This direct bolt in stuff does not take any differnces in stock placement of parts into consideration.
I have never heard this noise on any of the cruisers I own. I have a 4x4 Labs bumper with the resonator taken off and I did not hear it then either.
This chirping / whistling with the EMS System is LOUD...!!
All FZJ-80's have it. The resonator removes/reduces much of it, and often you can't really hear it unless you you what to listen for. It's also one of those things that once you recognize it, you can no longer not hear it.
Try cutting the resonator off and drive around for a bit. You'll hear the whistle real good. You'll then hear it all the time. :lol:
I've had people ask me if my truck is turbo-charged (with the OEM exhaust). :doh:
On the flip side, I've ridden with people that swear they can't hear it when it's plain as day to me. So maybe you're not the only one....
I would have liked to seen a resonator offered for the EMS kit. I think that would make a big difference in the whistle, and would probably quiet it down some.
Gee.... this story is like Deja Vu for me...:)
here are my issues:
Bill
TLCA#7390
That looks very wrong. Maybe whoever welded in the O2 bung welded it on the wrong side of the pipe?
It wouldn't be very difficult for an exhaust shop to cut and reweld it 180*, which should relieve the strain on O2 sensor cable and get it out of harms way.
I agree though that you should not need to do this. Hopefully Baktash chimes in here. It's a shame because the system is quite excellent and I'm very happy with it on my rig.
It sucks to hear that folks are having so much trouble with this system. Hopefully EMS/baktasht will step up and take care of it and use this as an opportunity to improve the product.
It doesn't seem like there was a lot of thought about how this exhaust would interact with most of the usual 80 series modifications (transfer skid, sliders, 33" spare tire etc). Maybe a "version 2.0" could be done using a completely stock truck as a template and keeping these things in mind?
I think the biggest problem is the EMS who selling these is having them made in the NW and him being in Tx then dropped shipped right to your door hes out of the loop for any kind of QC .
The other part is since these are built when ordered they be using the jigs ,bends are close enough and just tossing the o2 bungs and brackets where ever its falls near the right spot.
These problems have most likely killed any future sales ,which sucks for everyone
Well.. it's like I said in the vendors forum,.. I think it's an issue with the center piece for me, although the forward O2 sensor is also in harms way... if that gets resolved I have no issue with keeping the exhaust. Without that, its worth nothing to me, and nothing is what I expect to be out of pocket. I own my own company. if I had customers that were this disgruntled, Id eat the $$ and hope we could do business in the future. The thing is to never let it get to this. this could be a huge cash cow for EMS. I think that its basically good quality and all.. and thats one of the things that bummed me out when it didn't fit. It's a pretty shelf ornament at this point.
Bill
Bill
If they had actually built it for the majority of us, but they didn't. It should have been a nice mandrel bent 2.5" system with a high flow, but NOT straight through, muffler and resonator combo that bolted up to the stock location. 3" is just stupid overkill for everything but a turbo'd 80 running over 350whp(That's over 400 crank HP on this AWD)
The EMS exhaust is 2.5".
Got a call from EMS a short bit ago and Baktasht said it looked like I received the incorrect center section. We are working on resolving this now. I also sent him pics of the y-pipe section in case that was incorrect also.
As I stated before, I see that he has a great rep here on Mud... and this is going a long way to me agreeing with all the other positive posts about EMS. Seems very stand-up. He will be shipping a new center section so that my isse can be resolved. We'll see if I can get my slee skidplate on there again also. I have no issue with a mistake,.. We all make them.
Regards,
Bill
Whoah, there's so many people in this thread that I don't know who is asking what and who to reply to. If I miss a reply to you, please post and I'll reply.
Bill,
Good talking to you today. I have a new over the frame piece ready to go, just waiting on the pics to make sure we're not sending you a part thats the same as what you already have.
Our exhaust actually already is a 2.5" mandrel bent system. Seems like everyone's out on a witchhunt all of a sudden. :meh:
Filmpros (Richard), I've spoken with your builder Nat in extent several times over the last couple of weeks. It seems like you guys are happy with the build quality and the fitment, but you are wanting an exhaust that's slightly quieter (close to OEM). The chirping sound is almost definitely a small leak. A very small leak since from what I understood from my conversation with Nat today he is saying that it won't make the "chirping" sound while revving in neutral but makes the sound under load. My bet is that the leak is at the y-pipe/header joints and can easily be fixed by removing the stock donuts and replacing them with flange gaskets. I also spoke with Nat regarding adding a resonator and a custom tail piece to your exhaust system to make it quieter for you, he said he'll be talking to you about it this evening or tomorrow morning.
These are straight-through exhaust systems seemly best suited for forced induction modified 80's. SC or turbo. I had a modified big turbo car for years with a 3" straight system and it was louder than ****, 2.4L 50 trim setup @24psi. I wouldn't recommend anyone put this system on unless you really like BIG noise and you are running over 350 whp. 2.5" is good for anything below that. Heck, I've seen Dodge srt-4's dyno over 325whp with 2.25" exhuast so it's not like 3" is really neccessary.
Our exhaust is 2.5" mandrel bent with a catalyticl convertor and a very large muffler. I think you've got your facts mixed up.
I will post more later on, once I've calmed down.
The fit of the EMS Powered exhaust is absolute ****. I had to remove a heat shield, the rubber resonator on the transfer case, and both O2 sensors point straight to the ground. Dumb dumb dumb if you ever plan to wheel.
The tone is great, very pleased with that. The whistling is almost unbearable, much worse than stock w/ no resonator.
Joe, which parts of yours did not fit? The rubber insulator does need to be removed from the transfercase. It will not clear. There's simply no room to get a proper mandrel bend in there without getting near it. A couple of guys have adjusted the mounts on the exhaust a little to get it to clear the rubber insulator but I'd recommend removing it. The front O2 sensor will not hit the ground before suspension components do. Can you send me a picture of the rearward O2 sensor on yours? We may just need to adjust the jig.
Guys, if something doesn't look right and you're not happy with it, call us, email us. And give us a chance to fix it for you and update the design. Threads like this with a with this ganging up witchhunt mentality don't help anyone. We're not some fly-by-night company that will sell you something and run. We're here to make you guys happy no matter what it takes. Period.
