EMSpowered exhaust
Okay, looks like there's a definite issue with the post-cat O2 sensor location for the guys that have the 95-97 trucks.
Everyone who has RECEIVED their exhausts. Please check your pipe that goes over the frame (the pipe directly after the catalytic converter. If you have the O2 sensor positioned to where it is pointing downwards as it is in this picture, please contact me ASAP, as we need to replace your over the frame pipe. It looks like the post-cat O2 sensor position on the JIG was moved for whatever reason at the fab shop and these need to be re-made. We'll be re-making that pipe, sending it to you and then you can send the old one back (which we will reimburse you for the shipping cost).
If your "over the frame" pipe after the catalytic converter has this issue, please contact us to let us know so that we can get a replacement to you. admin@emspowered.com. Please include your full name (the name on the order), shipping address, and a valid phone number that we can contact you at.
Whoah, there's so many people in this thread that I don't know who is asking what and who to reply to. If I miss a reply to you, please post and I'll reply.
Bill,
Good talking to you today. I have a new over the frame piece ready to go, just waiting on the pics to make sure we're not sending you a part thats the same as what you already have.
Our exhaust actually already is a 2.5" mandrel bent system. Seems like everyone's out on a witchhunt all of a sudden. :meh:
Filmpros (Richard), I've spoken with your builder Nat in extent several times over the last couple of weeks. It seems like you guys are happy with the build quality and the fitment, but you are wanting an exhaust that's slightly quieter (close to OEM). The chirping sound is almost definitely a small leak. A very small leak since from what I understood from my conversation with Nat today he is saying that it won't make the "chirping" sound while revving in neutral but makes the sound under load. My bet is that the leak is at the y-pipe/header joints and can easily be fixed by removing the stock donuts and replacing them with flange gaskets. I also spoke with Nat regarding adding a resonator and a custom tail piece to your exhaust system to make it quieter for you, he said he'll be talking to you about it this evening or tomorrow morning.
Our exhaust is 2.5" mandrel bent with a catalyticl convertor and a very large muffler. I think you've got your facts mixed up.
Joe, which parts of yours did not fit? The rubber insulator does need to be removed from the transfercase. It will not clear. There's simply no room to get a proper mandrel bend in there without getting near it. A couple of guys have adjusted the mounts on the exhaust a little to get it to clear the rubber insulator but I'd recommend removing it. The front O2 sensor will not hit the ground before suspension components do. Can you send me a picture of the rearward O2 sensor on yours? We may just need to adjust the jig.
Guys, if something doesn't look right and you're not happy with it, call us, email us. And give us a chance to fix it for you and update the design. Threads like this with a with this ganging up witchhunt mentality don't help anyone. We're not some fly-by-night company that will sell you something and run. We're here to make you guys happy no matter what it takes. Period.
I was just wondering what the effect will be of removing the rubber isolator? The wife and I use this as a daily driver at times and making the ride harsher or injecting vibration into the equation is kind of out of the question over a 50-60 mile commute. Can the isolator be modified,.. or can that center section be extended 1" across its top in order to clear the isolator/skidplates etc?
Bill
It was great talking with you Baktash and I am confident the aft O2 sensor positioning will be fixed quickly! No problem on that xfer case isolator, I haven't even noticed it's gone. I'll get you detailed pix and measurements shortly. Thanks again!
Bill
I'm not sure what the isolator's function is personally. I've seen it removed on lots of trucks and removed it on one of my previous FZJ's as well without any additional vibration. We'll see if we can get it to clear with a few adjustments to that over the frame piece. I'm sending you another email shortly as well Bill.
Hey,.. if everyone says you cant tell it's gone.. I'm cool with that.
Nice to see the vendor being responsive. However, he is not a supplier I can recommend.
This system is not a advertised.
I am returning the one I have and canceling the other order.
I am willing to pay freight both ways to EMS, but I am not willing to pay the "restocking fee" he is demanding on a system that I have to "fix" ... this system was not engineered properly and it was released to soon to market.
I will not pay a restocking fee on something that does not work as advertised. This is not a vendor I recommend. The right thing to do is take back the exhaust and not screw the customer.
I am a very fair person but I am BIG on doing the right thing. I can assure everyone they would never have this problem when purchasing products from my company. If you are not happy, then we either make it right or give you your money back. That's it. No nickel and dime BS.
Here are the issues:
* In showing the system to an exhaust expert, they clearly indicated that using "Flex Pipe" is a shortcut they do NOT recommend. It is the cause of the chirping sound and we had it checked. It is not an air leak and this should NOT be my problem. There are too many people posting here with the same issues we are having.
* Also, there are only two freaking brackets holding this system in. No where near enough. The system rattles, buzzes, clanks, and makes all sorts of noise driving down the road. Every time we adjust it, the system shifts during the next heating / cooling cycle. Again, an indication of penny wise pound foolish design and shortcuts that result in a variety of problems.
* The O2 Sensors are exposed and in a very bad place.
* Will not work with Dual Fuel Tanks.
* Last but not least, the system is LOUD...!! I mean LOUD to the point of being annoying to the point of not being drivable. I had Rami here over the weekend and he can confirm how loud it is. Not anywhere on the website page does it say this is that loud.
SUMMARY: Again, a lot of shortcuts, poor design with noise being made by the flex pipe, poor bracketing / mounting of the exhaust resulting in rattling and shifting / movement of the exhaust during heat cycles, poor placement of the 02 sensors, and loud beyond belief.
The system is not ready for prime time. I am going back to stock.
Wow, nice one Richard. Thanks for the threats and the completely unprofessional actions. Here's the reply I just sent you stating the same exact things you just did in your post.
emailreplytoRhchardFilmpros said:
Richard,
The accusations and name calling is just not acceptable. This has gotten out of hand:
Flex sections are used in modern exhausts to absorb movement. Movement from the chassis, movement from the engine, etc… Whichever "expert" you have gone to is either a self proclaimed "expert" making up fallacies or is just doing the typical "mechanic" thing by putting down a product to make his own work and his own knowledge. Flex sections are used in new Toyotas, BMW's, Mercedes, etc… I guess they're all crazy too. When flex sections are not used you end up with pipes being overstressed and cracking. Exactly what happens on most FZJ80's at the Y-pipe.
This is not something that was mis-advertised. It is how the exhaust is made, and you were aware of it. The chirping sound is from an exhaust leak. There's no question about it. Whoever is telling you otherwise is simply blowing hot air. Out of the 30+ exhausts that are out there so far, a couple of people have experienced the "chirping" sound you refer to, and they've most if not all been resolved and were exhaust leaks. USE THE GASKETS THAT I SENT!!! You cannot call me and ask what the gaskets are for. Then use different gaskets. End up with an exhaust leak, refuse to put the GASKETS THAT I SENT YOU on, and then blame the design for an exhaust leak.
You are the FIRST person that has said anything about rattling and buzzing. If there's rattling or buzzing, the exhaust is rubbing on something and needs to be adjusted. There's nothing about the design that is foolish and your builder Nat stated many times over the phone that he was impressed with the build quality. There have been no shortcuts in design. You are simply grasping at straws here to make a point. Your point is moot.
Again, this is not something that was mis-advertised. All the pictures of the system showed the way the exhaust was built, along with the hangers.
The forward O2 sensor port is not exposed. The rear ward O2 sensor port is in the wrong location which I posted on the forum, and let Nat know about and we should have the correct pipes shipping out to folks in a few days. This was something that was correct to begin with, and the jig was changed by one of the welders by mistake. Which we are fixing ASAP and replacing all of the pipes whether people noticed the issue or not.
It was never advertised to work with dual fuel tanks. In fact, we have it listed that it may not work with spare tires larger than stock, and there would be future versions of the tailpipe available to offer clearances for aux tanks, dual outlet exhaust, larger spares, and other various options.
Again, not something that was mis-advertised.
There are sound clips on the listing of the sound. If it's not for you, that’s something that you should take into consideration when doing an exhaust upgrade.
I will issue a refund to you in full. But just as you stated in your last email that I just received after this one. You are stating that I have not handled this matter properly. On the flipside, I strongly feel that you have not. From your posts badmouthing all over the forum to the accusations of mis-advertising the system. And now your idle threats.
I have nothing against you Richard, but jumping down my throat the way you have really has rubbed me the wrong way. I'm always more than willing to help and go above and beyond to make customers happy. But placing blame and calling names the way you have is just simply not acceptable in my book.
Your refund will be issued as soon as the delivery man drops off the exhaust. In full, including any shipping charges you paid
Richard,
I especially appreciate this line out of your last email:
alineoutofRichardFilmprosEmail said:
One pissed off customer does more damage to your business than 100 satisfied ones. Obviously, this is not something you care about
Also, very weird how this post was edited to the above but originally said the following:
Nice to see the vendor being responsive and it appears he is looking to the right thing. That is good..:)
I will return the one I have and cancel the other order and may revisit this when it is worked out.
The system is WAY too loud and we cannot find the air leak. Going back to stock for now.
Baktash - Thanks for doing the right thing and taking the return from us.
This has gotten out of hand. I have no more to say to you. Please stop emailing me, and ask Nat to stop emailing me. Thank you for the very unprofessional way you've handled this matter. Have a great day, and good luck on your build.
The Objective Viewpoint:
Exhaust experts with whom I spoke recommend flex pipe for big torque and offroading to allow some movement and not crack the exhaust.
Mine has 3 mounting locations and doesn't make any noise such as you describe.
Agreed on the aft one, but Baktash has promised a fix.
Sound is entirely subjective! I am very very pleased with the sound, it's not "loud" to me, a nice mellow tone - and barely audible in the 80 at highway speeds.
Baktash has provided me good advice and response times. When he comes through w/ the frame section fix for the aft O2 sensor, I will heartily recommend him and this exhaust.
From Wikipedia:
Trucks
In many trucks / lorries all or most of the exhaust system is visible. Often in such trucks the silencer is surrounded by a perforated metal sheath to avoid people getting burnt touching the hot silencer. This sheath may be chrome plated as a display feature. Part of the pipe between the engine and the silencer is often flexible metal industrial ducting, as in the image in the section "Terminology". Sometimes a large diesel exhaust pipe is vertical, to blow the hot noxious gas well away from people; in such cases the end of the exhaust pipe often has a hinged metal flap to stop debris and birds and rainwater from falling inside. Sometimes this exhaust pipes have some flex connector attached with it. This helps in minimising the vibration from the engine to be transferred into the exhaust system.
Flex pipes are not all that unusual, and they seem to be gaining in popularity. I was very much in the "I don't want it" camp when it was first suggested for my truck. Fortunately, I was convinced to try it, and have had zero complaints about it.
If I may, I'll add some tech if no one minds.
From doing several HG jobs and a few Y pipe installs I've come to realize that a certain sequence should be followed to ensure a good lasting seal at the manifolds.
The problem is that only 1 stud is captured on each manifold. The rest of the holes are very oversized and will allow the manifold to move around quite a bit before being bolted down.
It's my opinion this is to allow for plenty of adjustment in positioning the manifolds so that they can be bolted to the Y pipe with as little stress as possible and be properly aligned.
Here is what I do:
remove the manifolds, clean them up and replace the studs. (New England rust)
I then replace the manifold /head gaskets and place the manifold in place with new nuts (New England rust)
I tighten down the nuts to the point where the manifolds are snug but I can still manage to move them around.
Now I attach the Y pipe and bolt it into place tight to the manifolds.
Now that the manifolds are attached to the Y pipe I torque down the nuts to secure them to the head.
No two Y pipes will be the same and if you just drop the pipes and install the new ones you will have a good chance at having a leak at the manifold/pipe joint.
This is more about mounting the manifolds to the Y pipe and not the Y pipe to the manifolds.
They are facts...not threats.
Best,
Rich
Richard,
The facts I posted are tech...
Is there anyway we can take all of this BS off line. There is just no tech in this thread anymore.
Thanks.
-onur
The muffler was changed after the fact from the one he posted the sound clip on...did you know that?
The muffler is the same Richard. The only difference is that we had to get them manufactured ourselves versus buying them. The sound is identical. Dimensions are identical. Material is identical. And the internals are identical. You're grasping at straws to prove your point that nobody seems to agree with.
There are no "facts" that you posted. Just your feelings, and the thoughts of your supposed exhaust expert, which EVERYONE so far has disagreed with. If those are facts, I think the definition of "facts" needs to be changed in the dictionary.
You guys need a hug. With you Beno. There are better places for this.
Baktasht,
we are bunch of skeptical nuts. No one person opinion count that much as to not consider your product as a replacement for stock. And it looks like you are doing the right thing by taking care of issues. Regardless how they are being expressed. Good work and keep it up. Don't get discouraged.
Now back to tech.
If Richard's truck is typical EMS exhuast, put aside the chirping, than it is loud system and has to advertised as such. Nothing wrong with loud system.
My .02. I know nothing about the install, I did not open the hood or looked under the truck. I simply drove it to experience the FOR suspension and because Rich said I can drive it. And I don't say no when someone gives me a wheel. LOL
Wow.
I'm afraid to post that I am happy with the response so far. My issue was the center section. This was acknowledged and is being resolved.
As far as sound, I always liked the way those "other" pickups etc have that big throaty sound... and hope to have my truck sound a big "ballsier".
I'll see how everything fits and post an objective opinion when done (hopefully this weekend).
Bill
TLCA#7390
Baktasht,
Will you be offering a cheap, slightly used exhaust system? If so, let me know. :)
Baktasht,
Now back to tech.
Thanks for the kind words, we're always willing to do the right thing and go above and beyond the norm to make each and every customer happy. But when the customer refuses any help and is hellbent on slandering our name and product, there's little we can do. I even offered Richard that we'd make a tail section with a resonator for him so that it can be almost as quiet as his stock exhaust at no charge to him. He still refused and felt that he deserved a full refund when returning his used exhaust.
There's no difference between Richards exhaust or any of the other EMSPowered exhausts on other people's trucks. If Richard's is louder than other people's EMSPowered exhausts then something is wrong with the way it is installed, or something is wrong with the way the truck is running.
Baktasht,
You have PM.
