Electronic F & 2F Distributors
I'd like one too... How long out are they? I just bought your carb for my 71 1F, and have the stock retard dizzy with petronix. Need the vac advanced electronic dizzy! Also, will my petronix coil work with your dizzy? Thanks! FYI - I just plugged the vac port on both the carb and stock dizzy, and it runs good. Your carb is awesome! VERY happy with the carb purchase!
Any news on the Dizzy's. Just curious if this is something I can order for my 78 40
And if that doesn't work just go to this link cause I'm a tard when it comes to figuring out Woodys secret code things.
hi all i have one of these . putting on my fj62 . what wires go where > red wire coil ? black wire with plug to exsisting dizzy plug ? there is a extra plug near the vac advance ? and also have deleted the resistor coil . straight 12 volt coil . just joined 2 wires together from ballast resistor delete resistor . plugged in coil . any help really appreciate . as my wagon no go .
and thats the thing with this cheap rubbish no info on what type of coil etc , no tech info , cant find out what is the correct primary resistance on coil for unit , 2 distributors failed in a week , cant by modules etc etc
Does anyone know if there is a way to test the modules inside the dizzy. I rigged up a test light with a ground wire off the base plate to the - battery and the test light between the - battery and the - module and the + of module to + of battery and nothing happens. I thought this might work because I saw a guy on YouTube test his the same way.
anybody know the part number for the signal generator in a Trollhole F dizzy? Or what model year and vehicle it is from?
And a source, would be awesome.
Thanks,
Yes will work but it's a vac retard dizzy. You are better off using the other dizzy and not connecting the vac line until you can get a new dizzy.
Hi,
I’m after an electronic dizzy for my ‘74 FJ40 which is running the 3.9L 6Cyl 1F Petrol Engine and (from what I can tell) the stock points distributor with vacuum retard.
From reading through this thread, doesn’t look like the dizzy that everyone’s after has come in to stock? 🤔
I would love to see if anyone can source this or point me in the direction of an online store or ebay listing...
I’m located is Australia so I’m going to need International Shipping.
P.S I’m trying to stay away from resorting to fitting a PerTronix Ignitor II Kit & Flamethrower Coil as I’ve heard mixed reviews 👍
Look forward to hearing from you 40 experts!!!
I’ve uploaded some photos of my recently Raptor Lined (Factory Cadet Blue) shorty!
Hi,
Did you ever get another electronic distributor?
