Electric fan
I have not actually been into the cooling system for about a year. That was to replace my radiator which was leaking. It did get a little better but has been the same since. Exhaust was replaced about a year and a half ago from the manifolds back and it is tight. I think the condenser was most of the issue. So basically what I'm hearing is if the cooling system isn't working the way it is supposed to I should be able to drive around all day and low at 2 miles an hour and not have a problem
Yes. I had an issue creep up on me yesterday because all of a sudden my temps started rising again while sitting in line at In-n-Out with 108* ambient. But my fan clutch wasn't roaring at idle. Problem. So I *think* my brand new Amazon Aisin FC with 30k CST just took a s*** so it's finally time to put on the Landtank one.
Put the damn electric fan on. Why is everyone saying its not worth it? If you wheel your rig you should absolutely put an electric fan on. Is it absolutely necessary, some say no but I disagree. When you are talking about high load, low speed wheeling for hours and hours the more airflow you can get across the radiator the better. The stock fan is marginal at moving air across the coil, a good 14" pusher fan is much better .
I installed a pusher fan on my radiator for off roading and long mountain pass climbs. I've never experienced an overheating issue with this truck but I don't want to wait until it happens to decide to put the electric fan on. Just do it, wire it to a toggle switch inside and be done with it.
I don't know if that will solve your issue but it certainly wont hurt, I do think you need to have the system flushed and install a new thermostat to be safe.
I would put an electric fan on it if you are still concerned. I did a LOT of research years ago, and a "pulling" fan is more efficient than a
"pushing" fan. However, since you are planning on retaining your factory-type fan unit, then you will need a "pusher" mounted on the outside.
Also, mount it so it is on the "hot" side of the radiator so it cools with the most temperature differential. (Right side) Place the largest fan you can fit. I used a thermobulb switch from NAPA to make it automatic operation and I also installed a relay and toggle switch as a back-up in the event the thermobulb failed or I knew I was going to be going into a heavy work time and started cooling ahead of time.
The '80 is fan dependent, if the fan is weak they will heat up at highway speeds. That said, with your relatively cool conditions should be easy to make it run correctly. Put a pusher if you like, neat gadget, have seen them slightly help or hurt cooling.:meh: But, the stock fan with a good clutch should easily handle it, especially without A/C.
PM ToolsRUS then and see if he can set you up with a clutch. I had him redo my LT clutch and I've been very impressed. The highest I recall seeing is 198* and that was pulling a decent grade here in AZ with OAT over 100* at 70+.
Yesterday at lunch I got caught on a support conference call fo 50 min. 108* OAT, 151* IAT, A/C running cool and coolant temps ranged between 191-194.6*
Throw on an electric if it makes you feel better, but if everthing else is up to snuff with a properly setup clutch I don't think you should need one...
I can see the benefit of an electric fan when wheeling but clearly there is something not right with your existing setup. The three easiest things to check, IMHO, are:
1) quality of coolant. You say it hasn't been opened in over a year. So check your coolant, flush it, and put in new coolant
2) make sure there isn't air in your coolant system. Burp it.
3) check your thermostat to see what temp it is opening (or not opening) at. Replace thermostat and gasket.
Until you identify the problem all you are doing is throwing money at an unknown problem.
Well, first I think he should drive it now that he has the condenser out of the way. That will be the tell-all.
are you aware of the temps of your tranny ..?
Are you using stock rad and oil cooler for the tranny .?
I can see a bigger better cooler on front for your auto tranny oil along with an small fan for it with termo switch
