yes however an electric fan can use less horsepower than a mechanical one.
Correct, if the electric one moves less air. It takes X amount of HP, to move X amount of air, through X restriction. It's fan design law, where the HP comes from is irrelevant.
There is a reason why all manufacturers are seeing the benifit of running everything electric. Electric power steering, electric AC, electric fans. so on and so forth.
In the case of fans, until recently, most of it is packaging. It's difficult to hang a fan on the water pump pulley of a transverse mounted motor and have it do any good?
If a handy pulley is available, taking the power off of the belt is about the most efficient way to do it. Taking mechanical power off the belt, converting it to electrical (alternator) has significant loss, then converting it back to mechanical (motor) has corresponding loss. Not to mention the added complexity, corresponding loss of reliability, significantly higher number of failure points, etc.
The electric efficiency gains are made by more tightly controlling when they run. The whole design differs on an electric system, glancing at fan design law shows restriction being a huge part of the deal. Look at a good electric system, the coolers have large surface area, thin, most often single core, large grill opening, etc, in other words, low restriction, relatively free flowing, to work with a relatively weak fan. Now compare the '80, relatively compact/thick coolers, small grill opening, designed for a relatively powerful belt driven fan. This makes for a robust, reliable system, it's almost like someone designed it for heavy duty back country service, unlike the namby pamby setup in say,,, a Camry!
