- Thread starter
- #41
Sorry forget, when I get home I look up the new injectors I bought. Not bad prices either.
Tex
I emailed them and got the upgraded matched flow for the 4.7.
Back in Oct 2023 they were 476.22 shipped
Tex
I have yet to get the sequoia ECU going. Why, have to wire a relay in place of my Fuel Pump ECU in back that varies voltage 1-2-3 , low , med , hi based on engine load commanded by the 99 LC ECU.Following. I've seen some of the supercharger stuff posted but I think most are on VVTI 100s. I believe yours is the first I've come across that's a 98-02 4.7/4 speed.
Are you currently using the sequoia ECU? I wonder how different the 99 to 2000 ECUs are. I know I got ATRAC/VSC added
I'm not sure who you were looking at for the valve body but Cruisers and Company here in CO sells the valvebodies and they might have some in US stock.I would be ok with 25% but after discussion with Elate some of the items in the kit get hit with 50% while others are 25%. Additionally, there’s the potential for tariff stacking which creates a lot of unknowns in the final price.
I purchased all the supporting mods based on @obe12 thread here and @J1000 except for trans valve body because tariffs.
Plan is to run E85, 12 hole injectors, adjustable fuel regulator, piggyback ECU. Mine is a 99 with a larger throttle body so Elate said I’ll need a rear entry charger HTV1900 unlike the front entry here.
Again thanks for charting the unknown. Hopefully I can be part of the SC club soon@obe12 looks like you’re 25 miles north of me let me know if you’re tired of the charger and want to get rid of it lol.
lol, I was looking too. It’s unclear what the tariff is…10% or still 25 for auto parts. Let us know if you find out.
Well I did not swap a 5.7 to a 4.7. Not to start trouble on the forum boards by the 5.7 isn’t the engine far as reliably as the 4.7 is. Not that the 5.7 isn’t a good engine the UR is a good engine but compared to the 4.7 just can’t take the miles without its issues.
1. T chain left side tensioner
2. Oil leaks rocker box covers
3. Intake Valley pan coolant leak an issue to install if not following the book from Toyota requiring removal timing cover.
4. Head gasket left size between last two cylinders, if lucky no block distortion and head distortion to redo gaskets only. Comes down if head is out should you machine it then how much if you do. Partly maybe excessively long coolant services maybe a cause for gasket failures.
These engines are advanced and time consuming to work on.
Not your average DIY friendly.
First 100k maybe coolant leak issues and small oil leaks
Second 100 we’ll all depends…
3rd 100 k my opinion things will start happening.
The 4.7 history is better than that when you compare them.
Many can and have approached 1 million miles. Even 400k like mine and still going strong with original transmission.
If you change oil regularly, and service coolant more frequently the 5.7 may not show you these things. But oil leaks could happen as they age.
So how many miles on a used 5.7 plus cost and do you know the history of it.
2UZ are not perfect either, but they proven over time they are rock solid v8s, one of the greatest Toyota have ever built.
As the 5.7 age these issues will become more prevalent and known causes will be learned and maybe how to prevent issues.
I have a friend who has a tundra 5.7 and yep leaks oil timing cover / rocker box’s. Keeps it cleaned off and past 350k miles. His other 5.7 has the timing chain tensioner noise cold start and the oil leaks with 250k miles.
Early 5.7 has valve spring issues that got corrected too.
But these 4.7 VVTI 06-07 year 5 speeds are good. They like being boosted and really make them perform. Again keep it under reasonable boost and just drive it.
I have the 4.7 non vvti engine, 1999 4 speed boosted since March 2024 and zero complaints with original transmission.
I understand the 5 speeds are a little more sensitive to not keeping the fluid changed compared to the 4 speeds.
Just information take it as that.
Tex
Starting to agree completely on the 5.7 vs 4.7. The head gasket issues they are having over there give me major pause to buy a 200 vs. just buying this kit after I'd already modded my 100 to do everything I could ever need. Just needs more power in the mountains and this seems to solve that with a reliable option. I've reached out to Elate to get the process started.
Will do, will be interesting to see what the final number shakes out to be. Either way, much cheaper than a 200 series and rolling the dice on an engine problem. Shame we can't even look at GX550's or LX600s for an "upgrade". Zero chance I'm dancing with that TTV6 right now. The engineer in me screams "design flaw", as the machining debris excuse doensn't make much sense to me anymore.I really want to grab an elate as well but the tariffs have that on hold for now. Please let us know how the process goes and how much the tariffs add, if you don't mind sharing. Congrats on getting the process going!
So I've been in contact with them on my 2002 with cable TB and he's telling me I should go with the front entry version. I sent him pics of my engine bay. Wish this was a little more straightforward.The 25% tariffs for auto parts are under Section 232 of the Trade Expansion Act of 1962, and not under the “reciprocal” tariffs from the current administration.
It’s a complicated system based on HSS codes for each part of the kit. Potential for some items to be classified as auto parts with 25% tariffs and others under general reciprocal tariffs or under steel/aluminum parts under Section 232 that get hit with 50% tariffs.
From discussion with Elate some months ago, there is the potential for tariff stacking as well.
The price you see on the website is solely for the kit. The tariff/import fee will be calculated and billed directly to you by the importer/broker. In my experience, this has been paid directly to the courier before the package can be released.
Getting us back on track here and from discussion with Elate, anyone with an earlier model 100 series with the larger cable driven TB, they’ll need to use the Harrop HVT1900 which is a rear entry charger.
This is what he told me after I sent pics of my engine bay yesterday.I have the same TB on my 01, Travis said (this was a while back) the rear entry was a better choice for the monster TB. I ended up buying flanges and will make a TB adapter for the front entry SC. Fortunately I ordered before all of the tariff BS started - curious to see what that turns out to be as well.
