El Cochiloco
Didn't set the points since they were swapped out with a Pertronix ignition assembly when the HEI dizzy was removed.
Haven't screwed with the timing at all but definitely will look at it.
I was able to find a wiring diagram for the piggy and looks like we're missing all sorts of safety s*** on the alternator/ignition wiring. To get it safe again it looks like we'll need a ballast resistor, voltage regulator and the factory igniter setup. If we're going to run the stock distributor it's the only way we can go.
Not sure about labeling things like a voltage regulator safety s***, but that might just be me...
Vacuum lines/de-smog - I went down the rabbit hole: Vacuum Line at Carb Question - https://forum.ih8mud.com/threads/vacuum-line-at-carb-question.1331361/
Thanks for the link on the vacuum lines!
I definitely consider the voltage regulator safety s***, since without it we're getting maximum output from the alternator and in turn frying our unfused alternator wires.
Maybe "safety essentials"?
