Are you 100% sure that they both use the 46 mm bolt to hold on the harmonic balancer? I cannot see any 46 mm bolt on the HB on the engine that is still in the FJ. Also, there are no threads on the crankshaft that extends out of the remanufactured engine. Both harmonic balancer‘s appear to be press on as far as I can tell. Can you see anything in the pictures below that would indicate otherwise? Thanks for the help…
HB on existing 1968 engine in the FJ
crankshaft and key on the remanufactured 1967 F engine:
Please correct me if I’m wrong, but they sure look like press on harmonic balancers to me, but I’m just learning…
