Ok guys, I need some suggestions. Heres what I'm dealing with after mods. (Prior to mods it drove fine with zero issues)
I recently installed an Ironman 4" lift with caster correction plates and 35" AT tires. Took it out and immediately noticed and strong vibration once i got around 30mph and it would lessen the faster i got. It is primarily during accel and decel with some rattle while its floating between the two. First thing I did was take to a shop and had an alignment done, then checked the driveshafts for play. the rear DS had a very small amount of wiggle in the spiders so I swapped them with new OEM. Took it back out and still the same thing. So i pulled the front DS, locked the center diff, took it out and presto! the vibration was gone....mostly. I get just the slightest amount of vibe when i get above 60mph. I noticed that some PO had swapped the front DS joints with aftermarket so I replaced them with OEM, put it back in and im right back to bad vibrations. Next, measured angles, here is what I got:
Front pinion 5.5° up
Front DS 10° up
TC output flange 2.5° down (front DS)
TC output flange 5° down (rear DS)
Rear DS 14° down
Rear pinion 5.5° down
It would appear that the front DS operating angles are way off and the rear DS looks just about right, although with some research I found some that suggest the rear pinion shoud be about 1°-2° lower than the TC output flange to account for rear pinion lift upon acceleration. maybe that will fix that slight high speed vibration im getting in the rear. But to do that I will need to break out the wallet and get new upper control arms.
I have read countless threads on this common problem and have decided on a few possible options without going broke. keeping in mind that this isn't my DD, I swith back and forth with my Tundra. I want to drive it (because it's bad a$$!) just a couple days a week and take it wheeling at least once a month. This is where I need y'all to chime in.
1. Slee part time 4wd, since it drives so well without a front DS in it, less wear and tear on front axle, and I should get better fuel mileage. And not even worry about the stock front DS as I would only lock it in while off-road. I Live in SC and rarely see snow. Side note: I don't mind getting out and locking my hubs if need be.
2. DC front shaft. Do I go this route and take the chance that the vibes do not go away? I have read so many threads of people spending some much $$ chasing this problem. And If I do, how would I go about adjusting the front pinion angle to work with the DC shaft?
3. DC shaft and part time 4wd. (ouch $$$) Is it a bad idea to run option #1 with the stock shaft?
Any advice on other options would be appreciated also. And out of curiosity, will it harm the TC to run it without the front DS and center diff locked? Im not even considering that, I was just thinking about it as I was running 70mph down the interstate checking for vibrations.
Front DS 10° up
Rear DS 14° down
