drive shaft
73lndcrsr
I was wondering if there was another drive shaft that I could swap my flanges to so I have a longer slip joint.
There has to be another drive shaft that the FJ40 flanges could be mounted to.
Anyone know of a good starting point?
Yep, I was just thinking I could save some money by pulling something out of the yard and have the flanges swapped.
There has to be something that would work.
mini truck..
probably have to mod the flanges or get new flanges tho
How much slip is in the mini-truck?
*possibly* and inch more....but not much more, and that would only be on the front shafts, iirc.
If there were an inexspensive long travel drive shaft solution from the junk yard, you would have read about it A LONG time ago....and it would be in the FAQ....and high angle, tom woods and others would not have gone through the trouble of making high quality alternatives....
:beer:
Maybe check that place on 411 in Cartersville. They might be able to fix you up local. 4x4 outfitters or Flaming 4x4 something like that. Sombody ran into their sign. You know it?
dont know exactly witch 1 i used think it was fj 62 put 78 flanges in it and it bolted right into my 40 with soa and shackle reversal has a long slip joint and works well it worked for me but might not for you good luck
SOR or MAF sell a longer travel section but it is exsoensive.
You can take your drive shaft to local drive shaft shop and they can make a long travel for you using you existing parts. They change the spline to use their own products. They can also make a square on for you. Wouldn't run this in the rear though.
SOR long travel is actually an AA part #716370
Cheaper directly from AA (advanced adapters)
Nocents
high angle drivelines.
outstanding products
x2
by the time youve done all the shopping cutting welding etc. these guys will have it back to you
Thanks for all the replies.
I am sure I will just have one made. I don't know the shop in cartersville, i will have to go check them out.
There is a drive line shop near work, they can make anything I want for the right price of coarse.
They are reasonable for retubing one ($100), I will have to give them some specs and see what they come up with.
Just some additional input on this topic.
I did my 4.5 inch lift this weekend and now my shafts are fawked and need to be replaced.
Both shafts (IMO) need double-cardans at the case so that shot my local shop out of the water as they would have to order the cvs..
So called Tom Woods, talked to him and I have to send him both my TCASE flanges so the studds can be relocated to work with a double-cardan. He's doing it for free though...but still have to pull them and send them.
He's then making my shafts. So total quoated to me was 700 bucks for both shafts with Double-Cardan's and free work on relocating my studs on the TCASE flanges. Ouch...but that's okay...it will be done right and done once.
I flipped my 4" springs in rear and placed a 86 mini truck front in its place. The flange matched perfect on parking drum and i welded the holes and redrilled the axle side. Believe it or not the length was perfect, no mod on length needed.
I now need something with a long spline to replace my front, if anybodys got any ideas. I've got another 86 front but it has the cv and my front pinion is not turned so i don't think that will work. Check on ebay for that 85 or 86 driveshaft.
Good luckhttp://images.ih8mud.com/images/smilies/wink.gif
