If you're asking me, No, that's the point of frequent wheel bearing service.
If during an inspection I get a hard N to D or N to R clunk, I assume at minimum I'll be replacing axle hub flange. But a new OEM axle & flange will reduce the N to D clunk the most.
The propeller shaft clunk is different (during braking & acceleration), which lubing slip yokes often corrects. That's provided grease passes seal during lubing, otherwise more in-depth cleaning of yokes is helpfully. The last step if all else fails is drilling a small hole in backing plate of yoke to act as pressure relief valve.
Both these are general symptoms and cures. I'm sure you've seen exception as I have, and some clunk with mileage is certainly acceptable. But none of this is news to you
@PabloCruise, as you've a good handle on the 100 series.
