- Thread starter
- #121
hallman boost controller!?
Not a bad guess.
But it didn't work... https://forum.ih8mud.com/diesel-tec...4585-i-tried-do-something-awesome-failed.html
Just curious if you knew what oil pressure you're running? Also if you had a journal bearing or ball bearing turbo...
I have my turbo plumbed to the vacuum inlet and outlet (on its own as I have an electric vacuum pump) and I am seeing oil out the exhaust pipe... so I assumed that I did not have a good enough drain.
Perhaps I need to regulate the oil pressure... or rebuild the turbo... or weld a bung into the oil pan.... or more likely # 2 and #3
Journal bearing turbo. Oil pressure is 75 cold, 40 hot @3000.
Make sure you have the oil inlet restrictor in place.
Why doesn't anyone in this Diesel Turbo community drain oil through the oil filler cap?
Some auto makers do that.
Also a kit to turbocharge Toyota Tacomas does that.
Just thinking... it seems like a simple no brainer to me.
The short answer is that I did not do a lot of analysis about the thicknesses. Its a guess, primarily, based on some info on the web I found that said ".125 is a good thickness for turbo manifolds".
The longer answer is that my hands are kinda tied. I can't use tube larger than 2" without blocking access to the studs. I also can't use anything thicker than .125" or I'll reduce the size of the holes I can cut and then need to grind/cut/mill extensively to cover the 3B exhaust ports. If you were willing to do the extra work you could easily make 1/4" wall work, but I was trying to keep it simple.
Anyway, its an experiment, I'll let you know how/if it holds up. I can say that its impressively heavy already.
I'll get a restrictor in place... do you know what size I should have? (T3 Journal Bearing) I was reading online I should have around 0.065" like this:
Oil Inlet Restrictor - .065" hole size 1/8" NPT (for Journal bearing and larger GT BB) : atpturbo.com
why would you need thicker than .125 wall?
20 psi is nothing for that thickness wall![]()
the advice of using any hose that is not rated for continuious oil flow is flawed and should not be followed, that swollen deteriorated rubber crap is going directly into your oil pan. who in their right mind would want that to happen?
I think it has something to do with the truck being RHD. The pedals tend to be on the same side as the steering wheel.
beutifull build a Delight to read !!!
