Drew's MegaCheap homebrew 3b turbo thread
Man. You either have very bumpy highways over there or you're BJ42 has very stiff suspension Drew!
And it is so scary going around blind corners on the WRONG side of the road like that. :lol:
Man that is like my BJ60 rot-box with dead / flat suspension. about as ruff as that looked.
Our mountain roads not paved and theres a kidney workout..
Of course it's hard driving and holding on to the camera.
I like the post #97 , that he's just happy within the stock settings.
Thanks for the time spent post yota porn ;)
VT
99% of the time its not problem but yeah, that particular type of curve feels a bit questionable.
Brand new OME suspension... it is a bit stiff, but generally is quite comfortable. The one-handed camera action really makes it look bumpy.
Finally made it through the thread.
Looks like the goals of the project were met with great success. :)
I know you said you are pleased with the performance with stock fueling (excepting a desire for earlier onset IIRC) have you considered a charge cooler?
I ask because unless you luck out with getting the performance via a timing adjustment it will likely require more fuel to bring the turbo on earlier, which will likely elevate the EGT.
The other options being a tighter A/R on the turbine housing, or something whacky I've read on the internet.
I hear and read stories of people using the smog pump off a gasser, and plumbing it into the exhaust manifold before the turbo. Some people claim the extra gas, working gas, in the form of air, helps the turbo come online.
I've heard the same thing about water injection though, but I'm not sure how you would rig that up without having to flip a switch everytime (maybe a microswitch on the accelerator like the Nitrous guys use :confused: ).
I don't know if any of that helps, I hope it does, and I wish you continued success with the project. :)
Here's a little update - I've been using a tire pressure gauge with a hose running out the kick vent as a boost gauge. Finally got around to installing a proper one.
Went with another Auber job to match my EGT gauge - I love these little meters, you can set them up to do anything!
No problem reading them. The meters support an "alarm" function which closes a little relay across two terminals - I have a small buzzer attached to the EGT meter with a limit set at 1250F... so I don't have to look too much. Time will tell about the boost gauge.
That's a pretty nice job on the manifold. Can you go all of the way up 17 in 4h gear? Have you notice better MPG?
Almost. I can keep it in 4th and floor it and it will never overheat or shoot the EGTs up, but it will slow down on the very steepest parts, for example just before Summit. I usually downshift to 3rd there for a minute or so.
My speedo cable is broken at the moment so I haven't checked my mileage, but empirically (on a commutes-per-tank basis) there hasn't been a dramatic change in either direction.
Do you have 4.11 or 3.73 gears in it? I've turned up my fuel one turn and it will pull fouth if no one slows me down. I have no pyro. I get 10 psi at 2700. Don't know what it peaks out at since the gauge I was using only went to 10. In fifth gear at 70 mph flat ground it puts out about 7 psi.
4.11's. I'm at 8.0 psi at 2700, which is 1050 preturbo on the pyro, stock fuel.
Its fast enough. Most days I drive the BJ73 which has no turbo, so I"m used to the slow lane, harrr!
I just don't think you're busy enough, there Amaurer.
Running your own small busines ventures, school, cubicle-dwelling, being a cruiserhead, and LonelyBot?
You've got to find something to do with the time you usually relegate to sleeping!
Sweet turbo setup, as always, I'm in awe of your fab-work, and your Robot Boat (row-bot?) is a pretty cool idea, I've been reading up on it.
Ugh, tell me about it.
Its 3:42am and I'm awake finishing a presentation and CAD for my other, other business - engineering and design consulting; my clients have just ordered tooling for a new vacuformed product and there are problems with the part models.
I have to be at my day job in 4 hours.
Oh and the new (my last!) semester starts today.
Oh and I have three cruiseruser.com orders waiting upstairs to be finished and shipped (sorry guys - you know who you are, hee).
Keep an eye on Lonelybot though, going to be some big news in the next couple weeks... ;)
Ohhhh, one more!! I also ordered some new parts for this (turbo) project today. Stay tuned, I hope to have something fancy and new by the end of the week. I'll give you a hint, it involves a sweet new knob for my dash...
You seem like a busy guy, but I would love to see a more detailed guide on installing the boost/pyro/tachometer on a stock (or stockish) 3B. . . Maybe you have and I was too lazy to search for it?:hhmm:
FWIW, I'll probably be referencing this a lot when me and a friend with fabrication skills attempt to turbo my 3B with a Garrett GT2052S out of a SAAB 9-3. Although for some reason my friend refuses to fab a manifold out of square stock. . . Maybe it's because he's getting paid by the hour? XD
Keep up the good work!
Hmm, I can't remember if I posted anything about the pyro or not - I had the same unit on the stock manifold before I turbo'd. The pyro, the tach, and the boost gauge are all super simple - just attach the senders and then run the wires into the cab. I'd have a hard time making a post out of that, really...
Very cool build Amaturer. Just read the entire thread and ive gotta applaud your ingenuity and frugality on doing your build.
now if only i could find myself a damn 3b for cheap!
