- Thread starter
- #241
retrofitting occurred as my basket started shifting with the weight and jostling off-road. cam straps are rad!
fix (v1.0) for heavy load shifting in roof basket...
To reset the windows you need to turn the key to the "On" position and then roll down each window then roll it up and hold for a second or two. Make sure you do this at each window control other than the driver window. Then they will all work from the driver door controls.I had a weird thing happend in the store parking lot, like my (1.5 yr old) battrer was dead. Turn, no crank, nothing.. cycled back off, then on and all fine like nothing happened. Now my driver window doesn't auto down or up and I can open driver rear window (from driver door). Both passenger windows auto down and auto up fine (from driver door). The driver window switches have a flashing pattern now.
This happened before and I can't remember what the fix was. Maybe I just disconnected the battery and reconnected, . . . I dunno...
copy that! thanks.To reset the windows you need to turn the key to the "On" position and then roll down each window then roll it up and hold for a second or two. Make sure you do this at each window control other than the driver window. Then they will all work from the driver door controls.
Not sure about the flashing driver's switches. I would try again. Make sure the window goes all the way down and make sure you hold it in the up position for like 5 seconds. If that doesn't work then I'm not sure.copy that! thanks.
I've done this before to reset auto down and up (only from driver door)... I stumbled onto this fix after battery disconnect bu just fiddling with controls...
Just now I did this and still no go for driver rear (no down or up from driver door, but rear control operates window) and driver still doesn't go auto down or up but DOES operate. Maybe I'm not holding it long enough after full roll-down and full roll-up?
But the flashing light has got to be a code. . . . right?
When I popped the hood, the damn neg terminal was just laying there (pic above).. i have no idea how long it's been disconnected, but potentially 2 weeks.
I had a minute this morning and got it...Not sure about the flashing driver's switches. I would try again. Make sure the window goes all the way down and make sure you hold it in the up position for like 5 seconds. If that doesn't work then I'm not sure.
Interesting. Are you doing it while inside the car with doors shut? Not sure if that matters, but thats how i did it.I had a minute this morning and got it...
Holding a few seconds longer was key.
Driver is set now for auto down and auto up. Still no control of driver rear from driver door. Driver rear is controlled by back door switch but not auto down or auto up. And no flashing light anymore.
So progress but not completion.
You have to go around to every window and repeat the procedure along with the sunroof for it to reset. Doesn’t matter if the doors are opened or closed while doing it though. Go to rear driver door, lower the window all the way and then raise it completely and hold for a few seconds. After doing it to all of them you should be good to go.I had a minute this morning and got it...
yup....Interesting. Are you doing it while inside the car with doors shut? Not sure if that matters, but thats how i did it.
Cool, thanks.You have to go around to every window and repeat the procedure along with the sunroof for it to reset. Doesn’t matter if the doors are opened or closed while doing it though. Go to rear driver door, lower the window all the way and then raise it completely and hold for a few seconds. After doing it to all of them you should be good to go.
ah.I’ve had to reset mine a few times now due to having the battery disconnected while working on mods. To the best of my memory:
-start the truck
-started with the drivers door, opened the window to full stop, then closed to full stop. I remember reading that it needs to be a deliberate process and to hold for a few seconds beyond full stop in each direction (open and closed)
-repeated the same process at each location
-then finally completely open and close the sunroof.
And that’s it! Auto up/down and drivers control of all windows should work again.
