oh, you mean 0-100 k/h trap time...
well, i will put the HZJ40 i am building up against a HDJ81 for pink slips. both same gearing, same basic engine, both are turbo'd.
GM/Detroit Diesel 6.2L (~379 cu. in.) V8
Power: 130 hp (97 kW) @ 3,600 rpm
Torque: 240 lb·ft (325 N·m) @ 2,000 rpm
Bore: 3.98 in. (101mm)
Stroke: 3.80 in. (97mm)
Toyota 2AD-FTV (brand new Common rail, turbo, intercooled)
2.2 liters
134 HP (100kW) @ 3600rpm
310Nm @ 2000rpm
i would have to guess the milage will be the same.
as well the performace will be night and day different. (13BT vs 1HZ comes to mind).
longevity?
reliability?
It only takes a Formula One 2.4L V8/10/12 19,000 RPMS to make 750 horsepower![]()
The efficiency of the smaller, modern engine will be a whole lot better, but then again the older bigger engine has a "nominal" max. power which could be used for thousands of hours whereas the smaller has a "peak" max. hp which will melt after a couple of hours.
The torque curve from below idle up to the max. torque speed will be a lot fatter on the big engine as well, which will give the nice truckish feel.
VW sell these engines as industrial powerplants (albeit detuned), so longevity/reliability is beyond question. Where the chev 6.2 has a terrible reputation. Keep the oil, change the motor.
Ok I wanted to ask something that has been on my mind for some time now.
If you have two diesel engines that produce the exact same horse power and torque. Lets say 150hp and 300ft-lbs. One is a 2.0 liter and the other is a 6.0 liter. Lets say the 2.0 weighs in at 350 lbs and the 6.0 is something like 1100 lbs.
Not so fast! Physical size and characteristics matters and clearance around the firewall, front axle and radiator often dictates which motor gets the nod.They are both install into different FJ62's. Arent they still pretty much the same when used in a diesel conversion.
If they both have the same power band then I couldnt see why the smaller one would not work any differently then the larger engine. If not then using some math, etc... why? Maybe the mass of the flywheel used?
Having worked on said Chev 6.2 diesels, I can attest to them having reliability problems as from the factory in early models, but later models are just as reliable as anything else on the road as you can get. I just pulled the 6.2 numbers out because I realized how little power and torque they produced compared to other diesels and even power/displacement ratio was pretty low and could compare power and torque wise to modern diesels. Reliability of initial models wasn't part of the OP's hypothetical question.
