After a recent trip to the junkyard to pull a few York air compressors for an onboard air project (man, they're everywhere!) and a quick rebuild of my s***ty sears ear-splitting oil-less air compressor, I've been thinking... could a guy build an adequate to good performance shop compressor using a used tank, an electric motor, and one or a couple York pumps? I'd be looking for performance in the 10-12 cfm at 135 psi range, or higher cfm, for my current uses.
I've seen varying descriptions of a York output - the only one I can find right now is 4 cfm @ 90 psi running 1200 rpm... I know the actual calc includes displacement, cycle time, and pressure and hope someone could review that for me. Regardless, I suspect one or a pair of Yorks running at 1500-3000 rpm would have sufficient output. Std 110 v power would be ideal.
Assuming it's not a dumb idea out of the gate:
- any reason the Yorks would be unsuitable compared to an internally lubricated compressor pump designed for the application such as http://www.northerntool.com/webapp/wcs/stores/servlet/CatDsp?storeId=6970&N=87+90145&Ne=2
- what motor characteristics would be important/desireable? HP, RPM, etc? If new, something like this? http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200306767_200306767
If used, from what kind of application?
- any system design thoughts?... optimal RPM to run at? utilize selective activation of 2nd York pump through use of A/C clutch? others?... not looking for thoughts on tank size (yes bigger is better), need for unloader/pop off/ filters/etc.
I appreciate your thoughts and input... thanks
