Ditched the ABS
Here is the ABS unti fully intact. You can see there are 5 lines. 2 input (front/rear) and 3 output (front/front/rear) I believe? I think is where the T is needed? I didn't have time to trace the lines when I snapped the picture. I hope I am correct.
I was able to re-use existing lines with some creative tube bending ;p The threads and flare all match and are the same. Braking is much better w/o the ABS module and my fluid stays clean between annual flushing.
I'm good to go with all the parts/fittings to remove the ABS and the LSPV. I was holding back because I read on MUD the end fittings were different on the lines to the ABS and MC and required changing. From what Im reading on this thread its not the case. If someone that has done this can confirm the fittings are the same on the ABS and MC Im ready to proceed.
Anyone?
Is the above the answer to your question from the first page?
Almost makes me want to get a non ABS MC and front brake lines just to simplify things. Anyone know if the non- ABS MC from the 93-94 the same as the MC from the 91-92?
EDIT: Answered my own question. The fj80 and fzj80 non-ABS MC's are indeed different and not interchangeable. So if one wanted to replace the ABS MC with a NON-ABS MC you would need to find a FZJ80 non-ABS MC. In PKP80's diagrams above, the second photo is actually a fj80 diagram, not a non-abs fzj80 diagram.
I looked at the non ABS MC the only thing I could see different is the front fitting is on the side not the top. I could not see how this would help.
The front line tie together before they get to the MC on non ABS models. You can change a few lines and add some parts to make it work easier but I viewed it as more of a PIA in the end.
From what I understand there is a difference in flow rate for the ABS MC vs the NonABS MC, with the former having a higher rate. So I guess you could potentially blow wheel cylinder or caliper seals by keeping the ABS MC and removing the ABS?
For discussion only! Assume nothing!
LSPV
Eliminate the upper line and install 90° at LSPV
Remove the T from under the MC and install coupling
After this ^^^rear is done
Front
Use the T from under the MC for the 2 front lines
From the T shorten extra line to go to the front of the MC from T
After this ^^^front is done
I do not suggest anyone do this and if you do you do at your own risk. Yada yada
I'm assuming the three lines marked "del" mean delete?
Curious on info source?
The piston size is the same IIRC. What is flow rate? Dont see it any different then install a MC with larger piston size that is done every day without issues.
You are probably right. I may be confusing the MC with the residual valve. I think it has to do more with swapping from drums to discs, than it does swapping from ABS to NON ABS.
I'm going crazy :bang::bang::bang:
This has NOTHING to do with the LSPV. NOTHING. Just remove the ABS module and re-connect the brake lines. Very easy.
Haha. I think some folks wanted to remove the LSPV AND the ABS unit. Just adding to the confusion. Your diagram is exactly what I pictured in my head, the LSPV delete was just confusing me more. THANKS!
No? When you tie or T the 2 lines from the LSPV together you now have a no functioning LSPV. So why not eliminate it? My LSPV pictured:D
Not true.
The line from the FRONT brake circuit to the LSPV is a sensing line required in the event of a failure.
The LSPV is actually a LS&PV&BV (Load Sensing & Proporting Valve & By-Pass Valve). During normal operation the LSPV will only porportion the REAR brake pressure when the FRONT brakes are at normal pressure (as measured through the sensing line). If the FRONT brakes fail, pressure in the sensing line drops and the LSPV&BV operates in by-pass mode and applies full pressure to the rear brakes (i.e., no proportioning).
I do not recommend removing the LSPV sensing line if you have a LSPV, otherwise it won't work properly.
Also, the REAR brake line and the FRONT sensing line are not connected together. Why would you do that :confused:
Look at your LSPV and trace the lines back to the MC. The REAR is separate from the FRONT sensing line. They are separate brake circuits.
Hey 1fz thanks for posting that pic with the diagram, I have a solid idea now
The ones that you said "connect these with a T" are attached and go to the rear port correct? And the one that you said to attach to the mc attaches from the t under the booster and goes to the front port of the mc right?
"Connect with the tee" = FRONT brakes and LSPBV sensing line. The rear most port on the MC goes to a existing tee under the brake booster. One side of the existing tee goes to the LSPBV. The other side of the existing tee goes into your NEW tee. Look at the diagram. To make it work you need two (2) tees. One is existing, the other one you need to buy and install.
"Connect to MC" = REAR brakes. Remove and discard the short piece of tubing between the front port on the MC and the ABS. Connect the REAR brake line directly to the MC.
Lexus Technical Training Manual <link
See pages 13-14 for the full story on how the LSPV really works:)
Pictured MC line ends & ABS lines ends:eek:
Be careful when messing with your brake system if you dont know what you are doing
Someone make a damn video and post it on Youtube already (and yes disclaim ALL responsibility for peace of mind) lol !
