How did you tie in the two lines going to the rear?did you use two "t"s one to tie in the front brake lines and one to tie in the rears?
Order the T connector from Toyota, or regular parts store?
You said the rear has one line in and one line out. Then you said to bypass the a s you plug the line into the mc. I assume you plug the input into the rear port of the mc, but what about the "output line to the rear brakes?
I think you are getting confused. My understanding of this thread is that this is simple.
There are 2 lines going from the MC to the ABS sensor one for the rear brakes and the other for the front brakes. The line from the MC for the rear brakes only requires you to disconnect the line going into the ABS sensor and disconnect the line going out of the ABS sensor and then connect them together. This is bypassing the ABS sensor for the rear brakes. there are no other modifications needed and the LSPV is still in place and operating.
The line going out of the MC to the ABS sensor for the front brakes gets disconnected at the ABS sensor and must be connected to 2 lines going out of the ABS sensor with a T because the ABS sensor effectively splits the line from the MC to control the R and L sides separately. Some manipulation (bending) of the hard lines will be required to make this T connection.
Please correct your language as you're muddying the water further by using "ABS sensor" when you mean brake lines (as in plumbing, not electrical).
Very good explanation. Couldn't say better myself.edited, I hope it isn't that confusing.....
I need pictures, I don't have my truck nearby to look at
If you eliminate the LSPV the T fitting would not be needed, correct?
From what I understand yes plug output from abs into mc then remove lspv
