Ditched the ABS
Working on the brakes has lead to relocating the batteries inside the cab (behind the center console) and my new air source thanks to Warn (I'm free of having to fill up the CO2 bottle every couple trips). The warn will run the lockers, airtools, etc.
What unit is that? What's the power source?
SO who is going to get to doing this first? I hope to have the parts I need soon
Got a chance to work on the 80 today and realized I want to shift my whole plan around, but have to see if it is feasible. Here is what I noticed and what I am planning on doing.
In short, there are TOO many brake lines running throughout the truck I counted 10 connection points in the front area alone.
I plan on routing one hard line from the top of the MC down the panhard to the PS corner where I'll have it split into two lines, one for the DS and the other for the PS front. All in all I will eliminate the numerous coils need, for several extended brake lines, and it will seriously clean up the DS engine bay area. Stay tuned for diagram and further info
Can't wait to see the outcome!
By the way pkp, pm me back about that bar please
All feedback is encouraged and welcome for this project before I pull the trigger.
I am looking to eliminate all brake lines in the front portion of the truck. The front axle will feed both brakes off of one line that comes from the MC and T's off into 2, 1 going to the DS and one going to the PS.
The rear has 2 lines coming to the front MC. Currently one of the lines is under the battery box and the other goes to the 3 way bracket under the MC. I will remove the brake line in the 3 way bracket located under the back of the MC that goes to the DS front brake (this will now be fed by the single line mentioned above) and shorten the rear brake line that is located under the battery box and bring it up to the 3way bracket in place of the brake line that was going to the front.
That's the plan, What do you think?
QUESTION:
I do not have the truck with me, what size lines are the hard lines in an 80 series?
So your removing the lspv? Just running one line to the rear?
After driving Beno's truck last year without the ABS servo I knew mine had to go since the system has been disabled for eight or years. I reused some of the original brake lines and rerouted and installed some new ones to simplify the system. The second line gong to the LSPV was removed to simplify the rear circuit. Between looking at Beno's rig and this thread it was a very easy job. For those that would like better or more braking power this does work, at an every day 6500lbs I can finally stop somewhat effectively and the pedal is significantly more firm.
BTW my '94 uses 10mmx1.0mm inverted flare brake lines not the ISO bubble flares.
***Disclaimer: As others have mentioned this is the brake system of your truck, if you have the slightest reservations regarding your abilities or comfort level or if you don't know how the brake system works don't even attempt or consider this.
Pic of cleaned up area under the hood.
Nicely done folks... I'm thinking about this mod as well... my brake booster just went out, ABS has been dead for a while now and I think this mod makes this so much simpler.
Question - for insurance purposes have any of you talked to your Car insurance companies about this mod? I wonder if it invalidates it in someway.
Nicely done folks... I'm thinking about this mod as well... my brake booster just went out, ABS has been dead for a while now and I think this mod makes this so much simpler. Question - for insurance purposes have any of you talked to your Car insurance companies about this mod? I wonder if it invalidates it in someway.
If you talk to your insurance company about this, you probably won't have insurance after the conversation.
