Here's our Dissent front bumper powder coated in a hammer finished Septia brown and looking good! Can't wait for the rear bumper to be completed and mounted up. We have big plans for our 98 Cruiser........now we just gotta sell our Jeep.
Has anyone not been able to mount their Hi-Lift on the rear bumper? The base of my li-lift will not fit because it is about half a inch too wide. @benc do they make hi-lifts with a slightly wider base than other ones?
Yes, the HL-485 will fit and the extreme fits as well.Has anyone not been able to mount their Hi-Lift on the rear bumper? The base of my li-lift will not fit because it is about half a inch too wide. @benc do they make hi-lifts with a slightly wider base than other ones?
Right at about 160-170lbs.Ben do you have a final weight of the rear bumper plus carrier?
Sorry if I missed it somewhere else in the thread.
Awesome, thanks Ben!Yes, the HL-485 will fit and the extreme fits as well.
I didn't realize there was a cheeper version (HL-484) that does not fit when I was designing the tray.
You will need the base plate off the HL-485. Hi-Lift Parts & Services - Hi-Lift Jack Parts | Hi Lift Jack Company
After the factory hitch and crossmember are removed your looking at a net gain of around 100 lbs.
I have not done one yet but i can, there would be a slight up charge from the laser cutter for the one off arm ($50-75) but all I have to do is bend all parts opposite of the driver side arm.Ben - thanks for providing the weight.
Are you making a right hand / passenger side swing out for the tire, or just the driver side? We really like the spare tire on the passenger side for two reasons....easier to operate right handed, and easier to open as it goes out into the sidewalk when parked, not out into the road!
Trying to plan the build of a recently acquired '06 to replace our '99.
Thanks!
Just remove the base plate (it's only held on by a cotter pin) and store it in the back with the rest of your recovery gear.Has anyone not been able to mount their Hi-Lift on the rear bumper? The base of my li-lift will not fit because it is about half a inch too wide. @benc do they make hi-lifts with a slightly wider base than other ones?
That would work with most mounts however with mine there is a tray that allows the base of the high-lift to be bolted down and locked, this was actually to prevent the base rattle.Just remove the base plate (it's only held on by a cotter pin) and store it in the back with the rest of your recovery gear.
Discovered after I removed mine because the rattle was getting to me...![]()
Ben, I don't know if this has been asked, is there an option to tilt the spare tire away so that the hatch can be used without opening the swing out? The more I think about daily use, the more I think i'd want this as an option. I understand this adds cost, but seems like it might be worth it.
I have aboutBen, please let me know when you're getting close to shipping on the bumper so I can send the remaining balance over.
I also have to update you on shipping address.
I'm in Denver Mon-Thu this week and should be back in CA by Sat.
Time to start researching a good powder coater in southern CA!
I have about 8 rears that I'm going to try and ship out by the end of the week, yours in in those 8!Ben, please let me know when you're getting close to shipping on the bumper so I can send the remaining balance over.
Like @Ramathorn15 said, it would stick out way to far unfortunately.Ben, I don't know if this has been asked, is there an option to tilt the spare tire away so that the hatch can be used without opening the swing out? The more I think about daily use, the more I think i'd want this as an option. I understand this adds cost, but seems like it might be worth it.
