so.... which holes does the 2 long screws go in? I am guessing the outside 2 screws on the transfer case mount? anyone?
That's how I understand it.I'm guessing that there's no list to be on here for a set of aluminum skids ... rather, one should keep checking the website? Is that right?
@benc , any best guess on when these will be available to order? Leaving on a big trip (hopefully a year in Europe if the container shipping meltdown is solved) in June and wondering if I might be able to get these here in time…
@Joe422 , if you cannot solve the skid/borla interference I might be interested…
I did that about two months ago—heard nothing. Does that mean I’m on that list?If you guys want to send an email through the contact form on the website we do have an ongoing list to notify people of when the skid plates will be available for purchase/in stock on the new e-commerce website we will be launching soon.
Installed my skids today and figured I would answer my own question. The frame weight works with the skids with no issue.Just wanted to confirm before I order a set:
- Are the square holes in the mid skid for greasing the drive line or does the skid need to be dropped for that?
- Can the frame weight stay installed with the skids or does it need to be removed/relocated?
- It seemed earlier in the thread some holes needed to be modified. Is that still the case or is everyone able to just bolt it right up?
Just check them after any hard hits once in a while. People seriously use locktite on skid plates?Installed my skids today and figured I would answer my own question. The frame weight works with the skids with no issue.
One remaining question, is the consensus to use anti-seize on the bolts or some blue locktite? I thought I saw some mention of the bolts backing out from off-road use.
I think the instructions for the dissent front bumper said to use anti-seize for all the stainless steel hardware, so I used it for all the skid plate hardware too.Installed my skids today and figured I would answer my own question. The frame weight works with the skids with no issue.
I think earlier in the thread someone had some bolts backing out/getting lost after washboard travel. I guess its not as big a concern if they are just regularly checked.Just check them after any hard hits once in a while. People seriously use locktite on skid plates?
Anti-seize it is!I think the instructions for the dissent front bumper said to use anti-seize for all the stainless steel hardware, so I used it for all the skid plate hardware too.
Bummer... finally got around to install the skids on mine, and got the front 2 sections on fine, however the 3rd section hits my Borla Cat-Back... I guess the borla's piping is lower than the stock muffler. Will have to figure this out.
Unfortunately, no, I haven't made any solutions yet... Looking at the Dissent 3rd Skid, it is really beefed up right where the Borla hits... and to trim the skid for clearance, will dramatically negate the Skid's structural design. Im just running w/o the 3rd skid for now, still...Hey @Joe422 did you ever find a solution for the Borla exhaust and these skids? I already have these skids but it’s time for my exhaust to be replaced. I’m hoping you’ve made the Borlas work because the Doug Thorleys seem to drone too much.
Finishing up some this weekendIs there a write-up / instructions to install these yet? @benc @kem
I'll figure it, but saving an hour of my time with a writeup would be sweet.![]()
