Disillusioned
Heart of the Bluegrass, Kentucky, USA
Sorry to whine.
I finally put my hard top on this past weekend. Went out tonight to put the doors on and discovered the gas tank I had dipped and then sealed in February of 2003 was leaking. (How can things fail sitting in the garage?)
I got the driver's door on but it wouldn't close. Figured out the cage I installed this summer was not inset enough. The doors are about 6" shy of closing. I may be able to pull the mounting plates in and drill new holes but I may have to grind the plates off and re-weld them.
Does anyone else sometimes feel like taking their rig to the crusher to stop the pain?
Thanks for letting me vent.
Peter
It never ends. I put in a TH350 tranny, and was stoked to get in some wheeling before the snow, just to find out the tranny is cracked and leaks like mad in reverse. The good deal I got on the tranny ended up not so good at all. My wife is on maternity leave, so money will be tight until February, therefore no tranny for me :mad:
Thanks for letting me rant. You will have your cruiser up and at 'em in no time at all. Good luck.
peterb said:
Sorry to whine.
I got the driver's door on but it wouldn't close. Figured out the cage I installed this summer was not inset enough. Peter
You could modify the doors, or fit early doors which are much narrower.
I was going to put late doors on mine but had the same 'not closing' issues so left the early ones on.
If he already has an early door cruiser, then.....:doh:
Buy a good rainsuit and you won't have to worry about the top and doors.:D Then you won't smell the gas leak either!;)
Good luck.
Good luck.
You're not a smoker I hope :D
Mark - hehehehe I did that the first 7 months I owned my 40 cuz the gas tank was leaking. We had a couple days it was so cold and snowing my truck wouldn't start but the 40 would ..... out came the Carhardt's for the morning commute ;p
Soft Doors
Good luck.
Could you use the soft doors in a pinch????
I feeeel your pain brother! years back I spent many, many hours making my own cage for a v8 40 I used to have. I was so mad when the doors wouldn't shut I wouldn't talk to any of the shop help for a week. Two words: smoke hatchet!
Long ago I made a personal vow to never sell my 55. It will only be disposed of when it actually flips on one of those off camber cliffs, falling hundreds of feet to its impending doom. So many things going wrong lately with the 55. But on a lighter note, each thing that breaks does not actually keep the cruiser from running, just from running optimal. Also, go out driving with some cj5's, you will feel way better after helping with getting the broken jeeps off the trail.
The disillusion comes with any old vehicle. Now add some hard wheeling to it and excessive maintainance becomes key. If you want something that breaks a little less, get an 80. If you want something you can fix with nothing but a screwdriver, a 14mm wrench, duct tape, and a stick, your cruiser is the way to go.
peterb said:
<snip>
<snip>
Peter
Everyday! The cost, wrong parts ordered, crap bent out shape, the stuff I threw out that was needed and no longer available... The list goes on and on!
Like some others illuded to... That what makes it fun! I look at it like this:
I'm glad some of the stuff does work! (like my kick vents!)
snailwagon said:
.... If you want something that breaks a little less, get an 80. If you want something you can fix with nothing but a screwdriver, a 14mm wrench, duct tape, and a stick, your cruiser is the way to go.
:D :D
We were getting ready to whittle a diff drain plug for a friends rig one time when he found it a few hundred feet back up the trail.
The nice thing is stuff comes in cycles. I've had my current cruiser for 10 years or so. Long enough for stuff to start breaking again. :D
Peter
There are negative aspects for every hobby...Maybe time to take a break from the truck? I left my truck on jack stands untouched for almost a year, went biking and got onto another hobby but now I am trying to complete the last stage of my project by end of Jan 2006...Guess what while I was working on the truck last weekend, I realized the water hoses I bought from a respected online cruiser bussiness already rotted with big deep cracks only after couple years of little usage...Just another thing to do...but I'm still feeling fresh.
/td
i view those items as challenges.....think it out mock it up and build.....all the while i am learning new skills and patience....i love working on my cruisers almost as much as i love the work i do for a living.....i am just a lot better at what i do for a living......bring on the next set back!
osagecruiser
yes it happens to us all, i still have to open the drivers side door to unrole the windows due to the cage being so close to the door. doh!
Wow, thanks for all the responses everyone. It lifts my spirits to know other folks get discouraged occasionally.
You have good advice. I'll pick up some soft doors if I need to drive it over the winter. They'll work fine.
I also stopped by the mini-storage place on the way to work and rented a 10'x15'. Getting the rig outta sight and off my mind will be good for me.
I'm already looking forward to working on other projects and maybe getting some recreation in.
Thanks again.
Peter
