disc brakes
Misssoula
here's the problem...bought and installed man-a-fre conversion. After driving it for about 10 min. the brakes would lock up making the vehicle immobile. E-mailed man-a-fre said to take the check valve out of the M/C and adjust the pushrod. Did that, also replaced M/C, rebuilt rear drums. Drove it, the pedal feels fine than when you push hard on the brakes the pedal gets hard, won't stop than locks up. E-mailed man-a-fre, no response. Called 'em, said that weren't sure. I know there is someone who has had the same problems, I don't want a guess, I'm tired of bleeding the brakes and spending money on parts that don't solve the problem.
front or rear brakes?
Front brakes...no kinks...and I adjusted the pushrod, it's not locking up but the pedal pressure isn't consistent. Maybe lengthen the pushrod a little?
What year master & booster? When I switched to front discs I had the same problems. The fronts locked up because the pushrod in the booster was sticking out too far and not letting the master release all the way. Adjusted the pushrod and they quit locking up, but then you had to really stomp on the pedal to get them to stop. Turns out my booster was bad. My old leaky master had leaked fluid into it over the years. It was almost completely full! Replaced it with a later model used booster (40, 60 or early model mini truck booster will work) and the brakes work better than ever.
It's gotta be the pushrod. Once you get past this molehill you can climb the mountain of proportioning problems you are bound to have.
regarding the kit see this
https://forum.ih8mud.com/showthread.php?t=51271
I regret ever buying that thing. MAF tried but at the end of the day could not really help. For what it costs you can put together the strongest minitruck stuff available, and it all bolts on. I could never get the front brakes to lock up. I tried everything, different MC, booster, one then two adjustable proportioning valves, new brake lines, no kinks, a $100 pressure testing kit, different pad compound, etc. I could not lock up the front brakes on anything short of ice or banana peels. I had +1500psi at the calipers and had them rebuilt by the guy at Wilwood who claimed to do the Winston Cup teams' calipers.
Live and learn, like they say.
Edit: also see
https://forum.ih8mud.com/showthread.php?t=52357
https://forum.ih8mud.com/showthread.php?t=53129
https://forum.ih8mud.com/showthread.php?t=66258
