Okay full disclosure, this question doesn't pertain to my 55. But the front discs on a 55 and an 80 are pretty much the same....and if I ask this question in the 80 section I will open myself to 10% of the internet.
There's a longer story here that I will share in due course but let's start with the short story. Middle son has been driving the 80 and when youngest son was home he used it for a quick trip and said the passenger side brakes were rubbing. Boy were they. I would say 1/4" of the disc on one side was gone. The other side looked fine. So I installed new rotors on both sides but cannot get the two pistons on the side with the highly worn rotor to compress. I even tried a 4T porta power and no dice. They will wiggle back and forth with a pair of channel locks so they aren't 100% stuck, at least not in all directions. The opposite side cylinders compressed no problem and all 4 compressed on the driver's side without issue.
I have read that they can "pop out" but there is no brake fluid leaking (assumption on my part that fluid would be leaking?). FSM says to just pop them out with air to rebuild them and to just push them back in with the new seals and cylinders, which is exactly what I did on my 55 calipers. The only theory I have is that the first seal ring traveled out but not the second and now the seal ring that is out is somehow preventing the cylinder from compressing back.
I have new calipers on the way so I can just change them but thought I would throw the question out in case someone else has encountered this issue before. Thanks.
