- Thread starter
- #61
Yeah we are kind of getting into the weeds. I know on Pirate there is a guy selling load bolt setups for Land Cruisers to help prevent the deflection.
But even if you did all of this plus 30/30 300M RCV birfs and inners, you still have the 8” front R&P.
The point though like I said at the beginning of the thread is if you’re a guy that’s already going to regear and add lockers, I see zero reason not to do it.....
There are always going to be those people that can break a ball bearing with a rubber hammer but this should give significant improvements in strength for those of us with a little mechanical sympathy
The additional tooth length perhaps does make a difference when under extreme pressure, but usually the bad breaky kind of load drives the ring and pinion away from each other which moves the mesh pattern up and out. I think. So, i mean, the 100 series gear set is stronger for sure but if the carrier itself is physically larger then thats a more significant benefit IMO. This is in @Malleus wheelhouse. I really like the idea and I think anyone running 37s or in that ballpark should seriously consider this if an option
