Daddy broke my cruiser....
Orlando, FL & Southampton, NY
It seems everytime my Dad borrows one of my vehicles, it comes back with sumthin broken :rolleyes:
Today was the first time driving the cruiser and the first thing he does is strip my antenna mast by turning on the radio under a low hanging palm tree where I usually park it :o
The motor runs fine, but the mast is stuck about half way :frown:
Pulled it up and left it there for the time being...
Anyhoo, anyone have the part number for the mast itself? (97 TLC)
Rick
86337-60080
OK, I got the mast the same day, but didn't have a chance to install it until today...
I was hoping that it would come out in one piece, but unfortunatly the majority of the reel was broken off in the the motor, so I had to yank it out :doh:
It was pretty straight forward, but I still followed John Davies' webpage as a backup :cool:
http://www.spokanister.net/vehicles_antenna.htm
And I'm sure glad I did cause I would've dropped the center backing nut for sure if I didn't read about it beforehand :o
Works great now :)
Rick
:lol:
Payback?
As for the antenna...I just replaced the mast on my '97 LC
It is SUPER simple if you can get the old mast plus plastic reel out as you just feed the new antenna mast in. My mast wasn't working when I bought the rig and I couldn't see the plastic toothed part so I assumed it was broken off down inside the motor. Took it all out and apart only to discover no plastic toothed piece broken off in there :o. DANG
Greased it up, put it back together, thread in the new mast and now the :princess: thinks I'm a genius! :D
Had I only known that the plastic toothed doohickey wasn't broken off inside the motor I could have turned an hour job into a 5-10 minute job :rolleyes:
I found the biggest PITA part was trying to reattach the motor to the fender...What a PITA to try and hold the motor in the right spot while trying to blindly thread that bolt in...:mad:
Also for future reference there is no need to fully extend your antenna. I slapped mine on the trail with a branch and it won't go down all the way so I just leave it where it is at about 10 inches extended. I also use Sirius so it doesn't take much to get those crappy channels that the Sirius needs to play on.
I usually have it set at the lowest point so when I turn on the radio, it only goes up a few inches and I raise it higher with the buttons if needed....
I guess the day my pop took it out, it was set to extend fully for some reason :doh:
Back home in NYC, it stays at the lowest point and I get a clear reception for all the stations I listen to, but when in Orlando, I usually have to go full mast cause I listen to Tampa stations :o
Hmmm.... I don't even have my antenna up at all for sat radio for either vehicle. In fact on my Z, I have an override switch so that my antenna doesn't automatically go up when I turn on the radio.
