- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,566
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
- Thread starter
- #681
I want to know where the oil went.
A few things I'm thinking on the rod breakage (possible scenarios):
1. The rod broke due to bad rod bolts and caused the motor to consume all of it's oil in a hurry
2. The oil was consumed due to to improper ring installation or something else (missed major oil leak), which caused extreme wear in that rod cap, causing enough stress for it to break
3. The engine was somehow over-revved.
4. The rod bolts weren't properly torqued
I just pulled a 2F out of a truck that was run for ~20 miles with zero oil and the rod didn't break, so I don't think that oil starvation caused the rod cap to come off in your scenario. It had to have been something else.
Wasn't 1, the first half of 2, 3 or 4, I can tell you that for sure. The oil definitely all came out at the same time, and I found out where. Back of the side cover, not a very visible spot. It went out of there and all over the passenger side firewall, but it had to have been on the road because I didn't see the leak.
Had extensive discussion with my engine guru, it was classic oil starvation. He also said it's not possible for the engine to burn up that much oil. Also the rings and cylinder walls look fine from underneath (besides the chuck the upper rod bearing half took out).
