cruiser lean
luckily my Cruisers aren't so bad with the lean, but my wife's Scout II leaned about 2 inches to drivers side after putting on a spring lift (it's sprung under with leafs like Cruisers...but springs are about 1" narrower than Cruisers!). when installing the new springs, we had removed the spacer included in the stock rear passenger side spring pack. After 8 months of shuddering every time I saw it, I finally lost hope that it would level itself out and replaced the 1/2" spacer in the PS rear pack.
...much better. It took about a week of driving it around to see improvement, but now it only leans about a half inch. In the six months since the spacer re-install, the lean varies day-to-day from negligible to 3/4".
Tim
Well, I went and put a 1/2" spacer on the Pass. side rear, and it took about 3/4" of the lean out, or about half. It's not perfect, but not such an eye-sore for me to look at anymore. I can live with it.
i put the rear PS spacer in the spring pack (bought the spacer from CCOT). When i first brought it home from the shop I thought it was better, but looking at it now I really don't think it improved it much. It still has a very noticable lean. Drives me nuts every time I look at it so i've decided to only approach my vehicle from the front, so far so good.
Just installed the SOR 4" lift kit complete with 4new leaf springs in my 75 FJ 40. I'm aghast she STILL leans to the left about 1.5 inches. I thought for sure the new springs would cure it! But reading the above thread this mystery seems to plague us all! Has anyone figured this out yet? After a "break in period" will this improve? For now i guess ill I'll approach from the front. Less heartbreak this way.
On my 5th cruiser now and this one also has the DS lean. All in the past I have always fixed them with the offending spring being rearched. But make sure a good spring shop does it with heat retempering the spring. about 100 bucks a spring. plenty of places on the web explain how to measure a spring so you can take the spring to the shop and tell them youwant "x" amount fo more height bent into it. If you take the cruiser to the spring shop it will cost three times that amount for them to pull and reinstall the spring. This cruiser is going to get 5/8 in the ds front and 1 1/4 in ds rear.
See all these "fixes" for the 'lean'. Anyone know what actually causes this?
For sale: 600 lbs of sand. Rust free. Great for filling up shallow graves, use in sand boxes, Jeep gas tanks, or for weighing down objects you are throwing off a bridge. Make offer. Conveniently located in Amarillo, Texas-- half way between New York and LA. :beer:
LMFAO. Mine leans a bit but I was searching this because my scout ii has a huge lean. Maybe 3" on a bad day. But it had a flat tire for years. Would that cause a lean that bad and will it correct itself now that it's back up?
email me for a copy of a old article about how to fix the lean. It is exactly what everyone here is talking about.
mcwinery@gmail.cm
george
oops see previous
ttp://coolfj40.stores.yahoo.net/booktoylancr.html
scroll down to parts 1-3 cruiser lean
I recently re arched my FJ60, and had about one inch of lean to the drivers side. Poor man's fix: I went to Home Depot and bought ten 60 lb bags of "snow sand" meant for carrying over the rear wheels of a 2wd pickup to get snow traction. I put them all on the high side, front and rear, and ran it like that for several days, trying to take it on rough roads when I could. Now the truck only leans one half inch.
Old thread, but relevant to me.
I have the opportunity to purchase either the left or right spare mounted Kaymar rear bumper. Either way I’m getting the one that has dual Gerry can holder. But din’t Anticipate having those cans filled normally....
So thought is if I get the spare version on my 74’, the 18” TRD PRO Wheelen and meaty almost 33” tire weight would help with lean.
Questions: will the extra weight on left help reduce lean or are there other factors beyond weight distribution?
Will the left mounted spare version bolt up to a truck that has stock spare on right?
Prepping for a Moab trip hence the bumper and desire for added fuel and water on rear.
Best,
LR
This sounds an awe full lot like the frame or suspension is bending. If weighing it down and them removing weight with an improvement is effective, what else could it be?
Did the Toyota tech bulletin talk to cause or just fix? I guess we’d know the answer if subsequent years saw additional stiffening members in the frame....
Interesting. I started a thread titled Frame Twist. I'm building my 1973 FJ40. I believe the frame itself has a bit of twist in it, without regard to any suspension. I simply had my frame on a level shop floor and it's off from front to rear. If I level the front then the rear is off about ½" and vice versa.
So I mocked up my rear springs, SOA, Alcans, Ruffstuff hangers. Dimensions good, squared to frame good, diagonals good, shackle angles where I wanted them with full weight on. In this condition, with the front end of frame on stands, no suspension, and letting the frame be where it wanted, the DS is ½" low.
Then if I leveled the front end, instead of letting the DS be low, it introduced a difference in the rear by ½". The front being more influential in how the rig will sit due to the weight of the engine, tranny, TC.
So now I'm trying figure how I can keep the rear level. I could add metal to one side when I weld on the spring and shackle hangers up front and see if it will then sit level all around- I guess:hmm:
And yes, revival of old thread!
My 1970 Fj40 has had a lean to the right ever since I bought it in 73.
Some times I think is worse than other times but the rig has tracked so good I have always been afraid of mucking up the geometry so have lived with it all these years.
A couple years ago started thinking the old springs were getting tired so put new rear springs on and it lifted the back a couple of inches and the tilt was still there.
Made a set of shorter shackles with the right side about an inch longer.
It didn't cure the tilt so if I should be so lucky I guess I will just have to put up with it that way for the next 45 years.
I'll be a hundred sixteen by then and might just start thinking of selling my Cruiser.
Wonder how much I can get for it by then?
A couple years ago started thinking the old springs were getting tied so put new rear springs on and it lifted the back a couple of inches and the tilt was still there.
Ok- I did install the ARB “block” P/N
ELSK06. In my case with spare on right (1974) it leveled enough to where you’d need to measure to tell the difference. I followed that with the Kaymar rear bar install and then out fitted with vintage gerrycan and cheap water can. Kaymar worklight pole fitted with Baja Designs S2 Pro and added a third tail/brake light.
Lastly; added a pair of LP9s and a dome light, also by Baja Designs.
So despite all that additional weight, leveling strategy held.
Now, I just need that Cummins R2.8 repower... Talked to them at Expo East, but don’t have $10k+ sitting around for that to be green-lighted by the Mrs!
Cheers,
LR
other than the end turning into a build thread, this has been super helpful!!!! I recently purchased a 77 cruiser here in Arizona. I have noticed a bad lean to driver. like most I assumed it was just bad springs. but as I have all the symptoms of the DS lean I'm going to look into this!! thanks mud!!!
Cheers,
LR
Truck is beautiful. I really dig the TRD wheels on there. havent seen that before! I had not heard of the ARB block. Is it taller than the CCOT one? It looks like a good solution too and maybe a little thicker than the CCOT one.
