coolant on engine block... from where?
SoCal - westsiiiide
Okay, I am missing somethng here and cannot figure out where this coolant is coming from.
I see/detect no leak at the temp sending unit, or the at the seal around the thermastat bell, or the hoses becuase of loose hose clamps. I can clean it up, go run the rig, come back and it is in those 2 low spots direclty opposite of each other. this is a new issue. But, I cannot get it to do it in front of me with my head under the hood with a hot engine at idle???
there are bolts right in the same area as you can see.
where is it coming from??
might be running along something and dropping there. thats all i got
I kinda figured that.... but from where. where could coolant run out from at that high level, wrong along, and deposit in those low spots?
is it indicative of something? wondering is someone else has seen this and knows where it is coming from?
could it be out the hose? it will find a way through.
if it were out the hose... I would think there would be signs (wet dust trail on portion of hose) or under load and heat, I would see it bubble at the hose or what not?
I cannot find a 'sign' - no streaks, no other wet areas (as the coolant will not dry up quick - even on a hot engine).
I just sat there and watched it for 5 minutes, made sure therma opened so it flows and nothing....
to get it to do it today, I cleaned it all off, went and drove, came back and those 2 spots had fluid. but I cannot get it to do it sitting in place.
I've seen a chrome housing like that leak between the chrome and metal. That amount of coolant can be just a teeny pinhole stream. That isn't the newest hose clamp in there either...
I'm guessing if you replace the upper hose, get a boring factory water housing and all new gaskets and clamps, the leak will disappear.
if you really want to find it . Rent a coolant system pressure tester. you can rent them from Autozone or checkers. It will allow you to pressurize the coolant system and 9 times out of 10 the leak will be very apparent. It will also let you test your radiator cap for accurate pressure relief.
WAIT - s***nit... I 'think' I found it?
The closer I looked at the sealant around the thermastat bell and the engine block (in the picture it would be the area of the bell facing the radi and hidden under the hose), I noticed a very little wetness along what looks like a paper 2cm long ultra thin (literally - I put a corner of a piece of paper in it) opening. Well, when I put the edge of the paper in it went into the opening about 1 cm and came out wet. I guess that must be it?? surprised that that paper thin opening would allow enough fluid to flow out and back and pool up.
but I see no other option.
And I did recently (months ago) work in this area flushing the system. I guess the sealant I used was thin there and just gave out.
Currently, I have the thermastat bell, than a layer of special silver sealant for thermastat bells, then the o-ring. I will have the check that o-ring or maybe when i pulled off the bell housing and cleaned it, maybe I did not get off the last layer of sealant and there was a void.
I kinda had a similar problem in my radiator, but it only leaked when the engine was running. To test it, I disconnected the hose from overflow tube on the top of my radiator, and used and air nozzle to GENTLY pressurize the system. I think I had it regulated to 5 psi. I was able to track down the leak pretty easily after that.
I think i know what the problem is. Your engine is too clean. If it was as dusty as mine, you'd be able to track down the leak much easier. I dunno much about your engine, but my guess would be it's coming from the bolt holes next the each puddle. If it were coming from the hose, I would think the chances of it splitting evenly and running down both sides is pretty slim.
